Old 09-28-17, 08:11 PM   #21
We have it so when you turn on the bathroom light it starts the recirculation pump. We use a different amount of time depending how far you are away from the tank. This really helps that so no water is wasted here. We waste less water than a most tank heaters.
The hot water pipes and the return lines are all insulated.
Old 09-29-17, 07:53 AM   #22
I was going to wire it in on the light switch or put the circulation pump on a count down light switch timer.
Old 11-26-17, 05:02 AM   #23
Mini
Mini's Avatar
I would in your place have installed several tankless water heater
Mini is offline   Reply With Quote
hot water, tankless, water heater
