Old 04-25-18, 06:04 PM   #21
You can do power factor correction on motors and transformers.
All my welders and air compressorsare power factor corrected.
I tried to power factor correct cheap low power factor florescent lights, but adding capacitors made the power factor worse.
Might be able to power factor correct magnetic ballasts some what.
Cheap power supplies create phase distortion.
Old 04-26-18, 11:08 AM   #22
u3b3rg33k
From what I was reading in that article, in small power supplies, active PFC circuitry is both fragile and expensive.
From a facilities standpoint, it's probably cheaper (and more reliable) to correct the power factor at the transformer feeding lighting panels than it is to have individual pfc at each fixture.
Old 04-26-18, 08:09 PM   #23
Some Dell servers have the option to disable PFC through the BIOS. The efficiency gain from bypassing PFC is worth it even in some commercial environments.
Old 10-26-18, 02:09 AM   #24
daiphucka
Location: 375 QL13, Hiệp Bình Phước, Thủ Đức, Hồ Chí Minh
I want to see more ideas
daiphucka is offline   Reply With Quote
ballast
