Old 09-18-17, 08:32 PM   #11
WyrTwister
My 30 pound max baby scale has a problem working at the high end of it's range.. Not gonna work..
Saw this unit on Ebay.. And same model at Amazon for a bit more..
One good review too.. https://www.amazon.com/Zeny-Electron.../dp/B014RHV87A
220 lbs Electronic Refrigerant Charging Digital Weight Scale with Case for HVAC | eBay
Anyways, the question to the old Pros..
Will this scale be good enough for a DIYer who uses it a few time per year?
PS: This scale would be used with the stuff on http://ecorenovator.org/forum/sale-t...y-machine.html
Thanks for any comments..
How did your scale turn out ?
I ordered one from EBay that looks like the one you pictured .
Hope to receive it in a few days .
Best wishes to all of you and yhose dear to you ,
Wyr
God bless
Old 09-18-17, 09:40 PM   #12
One thing that I just knew was going to be a problem, was the display time-out.
But, after using it for a while, I found that just pressing the Unit button,
would turn the display back on, with no loss of the reading.
The current weight stays, even when the display goes to sleep..
It's a great scale. I've used it to test the accuracy of other scales..
Old 09-18-17, 09:53 PM   #13
WyrTwister
Thanks for the review , looking forward to giving it a once over .
Thanks , my friend ! Best to you and yours ,
Wyr
God bless
Old 09-20-17, 07:14 PM   #14
WyrTwister
Received the scale yesterday . Looks exactly like yours , but your photos are better ! :-)
So far , I just installed the 9 VDC battery and verified it works .
Best wishes , :-)
Wyr
God bless
Old 05-13-20, 01:04 PM   #15
Ok no more using a bathroom scale I just picked up the same scale for $67 shipped off ebay.
This should make HVAC job more accurate
Old 05-13-20, 05:15 PM   #16
WyrTwister
Using a bathroom scale is a drag . :-(
That is why I bought the refrigerant scale , too .
Wyr
God bless
