Old 08-12-14, 08:14 PM   #11
BillS111
You were talking about even setting the thing on the floor & making some kind of window-adapter... their HRV will run in any position, but there is an condensation issue with any HRV and theirs relies on gravity, so it does need to be upright.
BTW, there are other window mounted units, but they don't have anything close to the same efficiency.
Study the drawing really closely, you're not so far away from your goal.
True. It looked like it would only work inside a wall, but i can see if it will work stand-alone.
HRVs have a condensation issue? what is the issue? (will an ERV work better? long term, this unit will be used in Miami)
Do you know of any window mounted units? I have been having a hard time finding them.
Thanks for all your help.
BillS111 is offline   Reply With Quote
Old 08-12-14, 10:56 PM   #12
If you're bringing too-hot air from outside, it will hold more water than the cooler inside air. When you are cooling that air with inside air, it will drop it's moisture when it reaches the 'dew-point'.
The opposite flow is true for the same reason.
ERV's could help.
You'll just have to Google your guts out til you find it.
That's what I did.
I never bookmarked the thing.
BillS111 (08-12-14)
Old 08-12-14, 11:03 PM   #13
BillS111
Thank you!
carbon dioxide, co2, erv, hrv
