11-30-18, 03:48 PM | #4 |
It has 2 heat exchanges so it can vent with PVC pipe.
The keeps venting very cheap. It will only do one or the other. I just use it for domestic. I paid $1,096.16 shipped with isolation valve kit.
Tags |
efficiency, heating, hot water, hydronic, tankless |
