12-24-11, 02:21 PM | #1 |
Kitchen Instant hot water dispenser
We have a on the counter Hot Water Airpot that keeps about a gallon of water very hot. It is always plugged in and is in use everyday. Its been in use for about 18 years now.
Its not pumping out the water very well now and I think its time to upgrade. Who has experience with the tankless instant hot water units? Maybe the one with the tank would be good too, so we could use some ideas on that. |
12-24-11, 04:33 PM | #2 |
12-24-11, 05:28 PM | #3 |
Its not pumping the water out. It must be the seals wearing out. The water is plenty hot. Also, we are trying to find ways to conserve energy. Imgeo, you'll be the first one on the list.
12-24-11, 11:40 PM | #4 |
Home Improvement Goon
If you're really trying to conserve energy, tear it out.Do you really need 3rd degree burn hot water available instantly, all the time? Even at 3am? just plug in a $10 electric kettle when you need really hot water. /grumpy
12-25-11, 01:04 AM | #5 |
+1
12-25-11, 02:18 AM | #6 |
Tankless whole house units don't usually save energy or water since you have to deal with the 'cold slug' that comes between the warmish hot water and the cold water that comes before the unit can heat the water. I've experienced one of these units at someones house, it used a fair bit of water before the temperature settled enough to take a shower. For point of use, an electric kettle is probably a better and cheaper option both for running costs and intial cost versus a point of use water heater. Where I live the cheapest option is a tank heater running off natural gas, ideally one that is well insulated and condensing(once we get a good one available). Heat pump units come next but now we are a little off topic. To heat up a pot of water an electric kettle after pulling from the cold tap would be your best bet for saving energy and water.
12-25-11, 10:57 AM | #7 |
Knowbodies, tear what out?
I don't want a whole house instant water heater, just a point of use one. We actually use the airpot one we have now many times a day. Turning on the stove to heat up a pot of water in my opinion would not seem to be cost effective. But the electric kettle airpot on the counter is plugged in all the time and keeping the water hot. Plugging it in at the time of use would require the unit to bring the gallon of water up to temperature. How is that cost effective? Maybe its cheaper to do it that way? |
12-25-11, 01:52 PM | #8 | |
So why bring a gallon of water up to temp if you don't need that much? An electric kettle would allow you to heat only as much water as is needed, and heating a smaller amount will give you hot water much faster.
12-25-11, 11:59 PM | #9 |
Instead of keeping a gallon of water hot all the time, why not get a Sunbeam hotshot? It heat's a cup or so of water in a minute or two to just below boiling. It's an amazing little device. I don't have one, but my friend did when we were growing up and we used it almot every time we were there for Ramen soup or hot chocolate or anything else that needed hot water. I'm thinking about getting one for my dorm in college.
Amazon.com: Sunbeam Hot Shot Beverage Machine: Kitchen & Dining I've always wondered how it gets the water that hot that fast. It just doesn't seem possible when you compare it to anything else. HTH, Adam |
The Following User Says Thank You to launboy For This Useful Post: | Geo NR Gee (12-26-11) |
12-26-11, 10:17 AM | #10 |
Adam,
Thank you, that is what we are looking for. One with auto shut off, quick to heat and compact. Perfect! |
