Old 07-29-10, 04:05 PM   #21
I tried to find mastic before going with the tape and I could not find it at the local stores.
Old 07-30-10, 08:17 AM   #22
bergenm
Eco-Geek
bergenm's Avatar
Send a message via AIM to bergenm
As far as using Duct Mastic on an operational system. You would want the system shut down for a while. But the stuff we use here in the factory is normally good to go in 24hrs. I'm sure the label on the tube/bucket is your best friend though.
Last year when I was going to do this to my house there wasn't any in stores either. I bought it from the modular factory where I work. But when I was reading this thread I looked on home depot site and it lists a tube and a 1/2gal. bucket of air duct sealant. I think the stores are coming around to the fact they have to start carrying this stuff.
bergenm is offline   Reply With Quote
Old 11-10-10, 06:19 AM   #23
And I tried sealing it up with the aluminum tape. It seemed to stick to the wood alright but I'm unsure how it'll hold over time. For now, its better than leaving nothing there. If you have any good ideas here let me know. I had thought about cutting up a sheet of metal and screwing into the wood on each side making an L shaped piece.
Just a quick update on this. While I was insulating my pipes last week or so, I took another look at this to see how it was doing. Everything is still sticking and sealed fine.
Old 12-08-18, 02:59 PM   #24
pinballlooking
pinballlooking's Avatar
That was some major improvements in covering up air leaks.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 12-08-18, 03:32 PM   #25
CrankyDoug
Keep an eye on the aluminum tape where it attaches to the wood. Mine held for about three years but eventually let go.
The Following User Says Thank You to CrankyDoug For This Useful Post:
Daox (12-10-18)
Old 12-10-18, 08:48 AM   #26
I was actually just in my basement and took a look at some of my taping done 8 years ago. Most of it is still good, but there are definitely area that are leaking large amounts of air again. Time to revisit things!
philb (12-10-18)
Old 12-11-18, 01:37 AM   #27
u3b3rg33k
a quick and dirty reinforcement might be a couple of T50 staples across the wood/tape mating surface.
duct, hvac, tape
