Advanced Search |
06-19-14, 09:22 AM | #1 | |
DIY Solar Water Heater For About $30 In PVC Supplies And Paint
This is a very cool setup. I wonder about the longevity of it though. What do you guys think? DIY Solar Water Heater For About $30 In PVC Supplies And Paint Quote:
06-19-14, 10:31 AM | #2 | |
I think that in an economy such as ours, a PET plastic water heater would be a waste of time. It would be better to build (as randen does) or buy a substantial solar water heater system that would give us a life span that we, in an advanced economy (at the top of the empire pyramid) have come to expect. But in an economy, such as you would find in many parts of Brazil, where the 'middle class' is about 15% of the population, and the 'poor' are about 80% of the population, this design is absolutely brilliant, as it is using material from the waste stream and directing it to a useful application. If it holds up for a few months before being replaced, it is a huge success. I have come across many studies where apparently simplistic technical fixes were still completely out of reach of the intended population, and the 'improvements' were just not sustainable. Something to think about: the majority of people in South America live their whole lives, never experiencing a hot bath. -AC
The Following 3 Users Say Thank You to AC_Hacker For This Useful Post: |
04-23-16, 02:42 PM | #3 |
Land owner
It would last until the first hard freeze.
Which is something most of the US has to deal with. If you used most of your hot water during the hottest part of the day this would be perfect. But for most of us using this with out a storage tank and circulation pump wouldn't really save any thing. Also where I live, I have seen city water pressure up to 100psi. Let's say it does work a little too well, you heat the PVC up to 150°F and the pipe ruptures somewhere. If your water pressure is only equal to a column of water as high as a tank on the side of your house then you are good. |
11-18-17, 04:50 AM | #4 |
This is amazing system for heating water at low cost.
