Old 11-18-11, 07:33 AM   #1
pinhead
Default Microwave Electric Backup Heat Source?
I often see electric resistance heaters as a backup. What about a microwave system?
pinhead is offline   Reply With Quote
Old 11-18-11, 09:26 AM   #2
Patrick
Microwaves work by exciting the molecules within the food. To use it for heating, you will probably need some medium to absorb the radiation then transfer it to the air. If you have water coming in to your system, you could use a microwave to heat that. Magnetrons are about 64% efficient, but you could recoup some (all?) of the loss by mounting the magnetron in the air stream if it's a forced-air unit. IMO, it would probably be more trouble than it's worth.
Patrick is offline   Reply With Quote
Old 11-18-11, 10:32 AM   #3
pinhead
This number of 64%, do you know what resistance would be in comparison? I am thinking mostly of a toaster compared to a microwave. An amount of water: Toaster≈800W Microwave 1000W and I would think the microwave would be about 2 minutes to boil vs 10 minutes.
Old 11-18-11, 10:41 AM   #4
Electric resistance heating is 100% efficient. In a toaster you are loosing tons of heat out the top is all, so not all of it goes to cooking.
Old 11-18-11, 11:59 AM   #5
pinhead
So I was thinking an electric kettle and a microwave would be a better comparison, but I do not use either often enough to guess at the time to boil similar amounts of water. I am off to test it now. (the boss took his kettle home, so I will not be testing this afterall)
Old 11-18-11, 12:05 PM   #6
Ryland
If you want to heat a room quickly, instead of heating water or something else first, then an electric infrared heater would be the way to go, or good old heat lamps because they both will warm the skin instead of warming the brain and other high water parts of the body.
Old 11-18-11, 12:23 PM   #7
pinhead
Okay, I will go searching for the SEER or COP calculations, but here is the data from a microwave.
1 Liter of water.
1.855Kw / 60minutes = 0.030Kwh
Starting temp:
16.5°C T=0
33° T=1minute
42.6° T=2minutes
53.2° T=3minutes
Old 11-18-11, 12:35 PM   #8
pinhead
So I am completely lost on the calculations, and at the whim of Google.
But I am getting about COP of 1.4 without the circulation pump required.
Old 11-18-11, 03:05 PM   #9
You will absolutely not get a COP of 1 or higher with a microwave oven.
Re-check your assumptions & calcs.
Old 11-21-11, 07:37 AM   #10
pinhead
So 1 liter is 1000 grams. The heat capacity of water is 4.175 J/gk.
Over the three minutes the rise was 36.7°C, 4.175j/gk x 36.7k x 1000g = 153222j
1855W= 6678000 j/hour and it was .05h -> 333900j
Giving an efficiency of 45.8%
Not too sure what math I was using friday.
