Forum: Solar Power
12-22-21, 06:30 AM
This is just a poly capacitor.
The way you...
The way you read the identification is:
335 = 3300000 picofarads (0.000003300000 pico = 10 minus 12- there are five zeros before the 33) or 3.3 microfarads...
Forum: Solar Power
11-14-21, 06:30 PM
Forum: Solar Power
11-08-21, 12:30 AM
Forum: Solar Power
10-24-21, 06:41 PM
Forum: Solar Power
06-21-21, 09:46 AM
08-16-20, 09:11 AM
Yes, the spot with the black circle is a good...
Yes, the spot with the black circle is a good place to attach one wire of the fuse holder. Just apply the heat to the terminal until it melts, it probably has unleaded solder in the board. The...
07-23-20, 01:22 AM
For what it's worth, I have a gaggle of teensy...
For what it's worth, I have a gaggle of teensy soldering stuff for electronics. My go to is the Weller. All the super pro somewhat expert peanuts have their gadgets of the day, but guess what? Weller...
06-24-20, 08:49 AM
Go with good quality (e.g. Kester) 63/37 leaded...
Go with good quality (e.g. Kester) 63/37 leaded solder. Lead free is harder to work with so I do not recommend it for a beginner. For the iron, go for the TS100 if you want one that's portable or a...
06-24-20, 08:30 AM
05-20-20, 07:18 PM
Here's the web page for your unit:
http://airconint.com/wiki/index.php?title=Blue_Series_3
It looks like the power feed for the outdoor fan motor got burnt. I would definitely check the...
Forum: Solar Power
11-28-17, 08:38 AM
Forum: Solar Power
11-19-17, 06:36 AM
Good job!
A couple of things. In the future...
Good job!
A couple of things. In the future split your modules in two adjoining rows. You only need a foot or two between the rows. If you have to change a module ( I had a Bosch module go bad on...
Forum: Solar Power
10-31-17, 09:19 PM
Forum: Solar Power
10-17-17, 08:09 PM
Forum: Solar Power
10-08-17, 04:45 PM
Forum: Solar Power
10-08-17, 04:34 PM
Forum: Solar Power
10-08-17, 07:16 AM
Forum: Solar Power
10-03-17, 11:39 AM
Forum: Solar Power
10-01-17, 08:14 PM
Forum: Solar Power
08-31-17, 12:20 PM
Forum: Solar Power
08-30-17, 05:33 PM
08-28-17, 07:44 AM
Ok, so with that guy's earth tube test, he was...
Ok, so with that guy's earth tube test, he was transferring about 200 Watts with 2 holes. There are about 3500 Watts per ton of refrigeration, so you figure that out. Dozens of holes per ton of...
08-27-17, 09:27 PM
08-20-17, 11:37 PM
Grab somebody's old 10 SEER R-22 unit off of...
Grab somebody's old 10 SEER R-22 unit off of craigs list or letgo or faceb00k marketplace and start a project. I got a goodman 2 ton heat pump unit for 50 bucks this month, and saw a few 1.5 ton...
Forum: Solar Power
02-20-17, 02:51 PM
