Forum: Renovations & New Construction
02-28-22, 09:34 PM
Version II the damn computer ate V I.
ICF is...
ICF is great, materials cost when we did ours was about the same as single use plywood forms.
You may need a moisture barrier and insect proofing depending on...
Forum: Lawn and Garden
05-19-21, 12:51 PM
Forum: Conservation
02-26-21, 05:05 PM
01-28-21, 04:01 PM
The foam will bridge any minor defects in the...
The foam will bridge any minor defects in the grade, the down sides that I can see, infloor heating would be a bit tricky if you wanted it. (We love our warm floor), and if you are bermed at all (we...
09-30-20, 12:20 AM
10-26-16, 02:05 PM
10-08-16, 06:01 PM
EPS crete (DIY insulation infused concrete)
First off my camera is down, so no pics.
We first started reading about EPS crete about 5 years ago, it is fairly common in Europe, in NA not quite so much.
Here is how we do it.
We collect...
06-22-16, 10:56 PM
05-20-16, 10:38 PM
05-09-16, 10:58 PM
08-19-15, 09:07 PM
07-04-15, 09:48 PM
Ugly electric tractor.
Some flikr shots of the worlds ugliest electric tractor.
https://www.flickr.com/photos/technicotony/sets/72157655044675279
You can see the blade, fixed by a chain to the forks, being operated...
Forum: Biofuels
05-01-12, 12:56 PM
09-12-11, 04:09 PM
Just ran Sparky the electric tractor.
Have been puttering with the conversion on a Craftsman II (917 mod) Today built a quick and dirty battery mount and hooked up the wiring. Hopped on and toured around the yard. The motor is a series...
07-18-11, 10:00 AM
Thank you!
Mostly tomatoes with a couple of...
Thank you!
Mostly tomatoes with a couple of other things, that is swmbo's dept.
The two bigger windows have sliders at the top, I put the windows in upside down to get them there. with them open...
Forum: Wind Power
01-11-11, 08:54 PM
Sorry I do not get on the interweb much in the...
Sorry I do not get on the interweb much in the winter, as I have to go to a hotspot. We used to call a blade with no "twist" a drag machine, as the wind hits it and turns the blade, the classic...
Forum: Wind Power
08-31-10, 10:39 PM
