Forum: Solar Power
08-05-20, 07:58 AM
Forum: Product Reviews
05-17-20, 09:22 AM
I am glad to hear a positive story. I used to...
I am glad to hear a positive story. I used to work at cruise as a self driving test driver. They used the Chevy volt. When you are training they have you work emergency stop techniques.The bolt...
Forum: Solar Heating
10-16-17, 05:20 PM
What size do you need?
You can do it.
You can do it.
They come fully charged. You just need to pressure test them and vacuum them down.
Here is how I did mine. I had never done any of this before ...
10-15-17, 07:24 AM
The manufacturers in general design different...
The manufacturers in general design different unit for different regions or climates. If you are searching for a model that has a distinct energy advantage in the winter season, you have your work...
Forum: Solar Power
06-30-16, 06:07 PM
Forum: Wind Power
06-02-16, 09:11 PM
Forum: Conservation
05-20-16, 07:49 AM
Location...location.....location...
Hey all, have been reading this thread all week with great interest but just now actually have a few free minutes to jump in! There are of course MANY considerations when thinking about going...
Forum: Other Improvements
03-09-16, 05:06 PM
02-11-16, 12:05 AM
MEMPHIS91, That looks really good, and a whole...
MEMPHIS91, That looks really good, and a whole lot better than the temporary lash-up I used for my test. I look forward to your longer term impressions.
Would a thermal shot from further away,...
Forum: Solar Power
10-12-15, 10:03 AM
Forum: Solar Power
10-02-15, 08:06 AM
Rob
It is strange they are doing a limited...
Rob
It is strange they are doing a limited release on the 2016
"Chevrolet has a shortened model year for the 2016 Chevy Volt," said GM in a statement. "As a result, we have limited distribution...
09-05-15, 12:27 PM
Burning Down The House...
I had a dear friend, now deceased, who had been hit very hard by the vicissitudes of life, and although he remained a good and dear friend, his ability to think 'long term' and in regards to his...
07-15-15, 08:07 AM
Forum: Solar Power
05-14-15, 08:11 AM
I need to add some explanations why we built it...
I need to add some explanations why we built it the way we did. In most cases, this heavy structure isn't really needed. Matter of fact, one of the solar arrays in my area that was installed after...
Forum: Lawn and Garden
02-18-15, 03:53 PM
I have been considering building this passive...
I have been considering building this passive solar greenhouse. It is 12' X 24' It is 12’ wide and two rows of grow beds and the 55 gal barrels would leave about a 2 ½ foot walk way. I would like a...
Forum: Lighting
02-07-15, 04:06 PM
Forum: Solar Power
12-20-14, 05:14 PM
Set the water heater to 140F and then set the...
Set the water heater to 140F and then set the timer to only turn on at night. Then use a recirculating pump and fan coil to extract the heat during the day.
For storing cold, find a used A/C...
Forum: Conservation
12-20-14, 11:16 AM
08-21-13, 02:29 AM
08-13-13, 09:35 AM
If you are considering a heat pump solution, I...
If you are considering a heat pump solution, I would suggest doing a decent amount of research before installing a system. The performance is all over the place, depending mainly on the technology...
