Old 08-24-19, 11:05 AM   #31
I got my dc-dc converters last night. So, I printed up a little bracket for them. It went quick and easy and they fit great.
I started tinkering with them this morning. I started by connecting the dc-dc converters up to the battery bank with alligator clips. I then set the open circuit output voltage to 5V for the USB.
I was delightfully surprised that the dc-dc converter power draw with no load is a very low ~.35 mA. This will eliminate the need to switch them off and keep things simpler. It will loose .014 Ah per day with the two dc-dc converters hooked up. I think this is acceptable.
I also hooked up an old phone to the circuit. As expected, it started charging at about 5W.
However, when I plugged my newer phone into the charger it also charged at only 5W. I specifically got dc-dc converters that can handle more power output so I can charge at faster rates. So, I need to figure out what is required to activate the faster charging. If you guys have any info on this it would be much appreciated.
ID:	8698   Click image for larger version
ID:	8699   Click image for larger version
ID:	8700   Click image for larger version
ID:	8701   Click image for larger version
