Old 12-13-10, 10:28 AM   #1
Default Super insulate your hot water tank
A great article on how to super insulate your hot water tank. He also explains how to find the ROI for the insulation. Very well put together IMO.
IWillTry.org Super insulate your hot water tank
Old 12-13-10, 05:20 PM   #2
RobertSmalls
RobertSmalls's Avatar
Ah, yes, from Iwilltry, the author of a coastdown testing instructable.
Old 12-13-10, 07:43 PM   #3
Woohoo, you betcha!
Old 12-14-10, 12:41 AM   #4
Piwoslaw
Piwoslaw's Avatar
That's a good one You should put it in you signature so doesn't get forgotten.
Old 12-18-10, 01:38 PM   #5
RobertSmalls
It's all you, Piwoslaw.
Old 12-19-10, 11:37 AM   #6
PastTense
From the article:
"Where I live electricity costs about $0.07 per kWh so a typical electric water heater with no additional insulation might cost about $150 per year to operate. Depending on use, perhaps $50 of this is actually used to raise the temperature of the incoming cold water. The remaining $100 is wasted in the form of heat dissipation to the surroundings. "
Do you agree with these kinds of numbers as to how much of the energy is dissapated as waste heat? I was under the impression that the the substantial majority of the heat is used to heat the water. Anyone have better numbers?
Also note part of the waste heat will still be wasted--top and bottom of water heater.
PastTense is offline   Reply With Quote
Old 12-19-10, 12:17 PM   #7
The writer of the article did insulate the top. I don't think he mentioned insulating the bottom at all, but its a good idea.
Old 12-19-10, 03:26 PM   #8
RobertSmalls
I guess that depends on the amount of hot water you use, eh? But it seems plausible to me.
To avoid having to look up the UA of your HWH, try a simple test:
Record the temperature of your hot water. Shut off the heater, wait 24 hours, and take the temperature again. How much heat did you lose? This is equivalent to wasting a certain amount of hot water a day - how much?
Old 12-19-10, 08:12 PM   #9
That is a great idea. How would you recommend measuring the before and after water temperature?
Old 12-19-10, 08:59 PM   #10
RobertSmalls
I'd open the drain penis until it flows hot, fill a styrofoam cup with water (or nested plastic cups for the eco-friendly), and measure the temperature of the water in the cup.
The easy way is just to measure the temperature of the water in your kitchen, but that introduces all kinds of unknowns, like how much heat is lost in the pipes.
Edit: the forum censored out "draincock". Now it gets what it deserves.
Last edited by RobertSmalls; 12-19-10 at 08:59 PM.. Reason: It censored out draincock.
