Forum: Appliances & Gadgets
12-12-23, 08:54 PM
Hehehe firearm parts! That's so government like...
Hehehe firearm parts! That's so government like the J6 committee still pushing so the Cheeto can never ever ever make anything (great or otherwise) again. Meanwhile, 3d printers selling like Glocks....
12-12-23, 04:12 PM
The printer you linked to looks good for the...
The printer you linked to looks good for the price. You can download many 10's of 1000's of stl files from thingiverse. You can download the Creality slicer app and use it to create gcode - the...
Forum: Conservation
05-30-23, 06:00 PM
Forum: Conservation
03-11-22, 12:12 AM
Forum: Conservation
03-08-22, 02:37 AM
External heat sources like monobloc ashp, or...
External heat sources like monobloc ashp, or pipes that might freeze up, could be protected from frost damage with an anti freeze valve. Its just a valve at the lowest point in the plumbing, that...
Forum: Conservation
12-22-21, 09:15 AM
Forum: The Billiards Room
12-22-21, 09:08 AM
get tested!
We had antigen tests on hand for an upcoming christmas party with family. Wife and I have cold symptoms similar to yours, so I used one of the antigen tests this morning. It was negative. There are...
Forum: Conservation
12-14-21, 09:19 PM
Forum: Solar Heating
01-27-20, 01:50 PM
09-07-19, 07:43 PM
06-13-19, 11:57 AM
Well now... Main question is how much water...
Well now... Main question is how much water heater do you want? If you eventually buy another water heater, get one that has a warranty that will outlive you. Sounds like you originally found a...
05-27-19, 10:59 PM
09-13-18, 01:05 PM
Forum: Lawn and Garden
12-29-17, 09:41 AM
Forum: For Sale / Trade / Wanted / Web Finds
07-17-17, 08:09 AM
06-22-17, 05:13 PM
81 degrees 40% RH and 63 degrees with 75% RH...
81 degrees 40% RH and 63 degrees with 75% RH would be the same amount of moisture in the air. By turning on mechanical ventilation, you aren't reducing moisture content in the air. You are just...
Forum: Lighting
06-06-17, 11:03 PM
Forum: Renovations & New Construction
05-04-17, 04:34 PM
Panels themselves were $150 each
Inverters...
Inverters were $95 Each
Beyond that is racking, nuts and bolts, etc. etc. I''l have to add it all up sometime, but something in the ballpark of $8,000ish.
03-22-17, 06:48 PM
03-22-17, 03:59 PM
02-05-17, 03:45 PM
01-30-17, 11:32 PM
01-30-17, 10:10 AM
Just got the final bill from the roofer. Total...
Just got the final bill from the roofer. Total cost came to $5,400 for materials and installation. It also covered all trim, roof vent and cap, etc. This was within the range originally budgeted for...
01-29-17, 01:22 PM
01-05-17, 10:27 AM
