Forum: Solar Heating
10-17-14, 12:47 AM
Forum: Conservation
10-24-12, 07:08 PM
Forum: Conservation
10-16-12, 11:29 AM
Dragging this one up from the dead.
Since...
Since the last post I replaced and relocated the hotwater heater.
Basically it's a 60 gallon bottom entry 6year tank which I wrapped with the foil bubble...
Forum: Forum News & Feedback
09-21-12, 06:26 PM
Forum: Appliances & Gadgets
08-03-12, 04:35 PM
And Pictures finally ...
https://lh3.googleusercontent.com/-RkVYAFyq6lQ/UBssx6-u5iI/AAAAAAAATwA/vCW_fKX9zn4/s783/IMG_6008.JPG
The old tank in it's brilliant location
07-14-12, 04:33 PM
05-16-12, 11:13 PM
Forum: Renovations & New Construction
02-28-12, 12:54 PM
12-13-11, 03:50 PM
Since getting my new smart meter I've been...
Since getting my new smart meter I've been tracking daily electric consumption and a pattern has started to emerge.
I average 25 kwh/day right now doing nothing special. If I heat with the heat...
Forum: Other Improvements
12-02-11, 11:13 PM
New smart meter installed today
So today the electric company finally got around to my house and installed a new smart meter.
Sometime this spring I should be able to get readings on the web as to how much power I've used and...
Forum: Conservation
11-06-11, 06:25 PM
I figured it out.
my running average...
I figured it out.
my running average calulation is =average(K$23:K42) where column K is the kwh/day. the $ is K$23 is so that the average always starts from row 23 and K42 is because this...
Forum: Tools
10-17-11, 02:50 PM
10-16-11, 12:50 PM
10-13-11, 03:50 PM
why do you need an exchanger for the heating? ...
why do you need an exchanger for the heating? Just run 1 line for the domestic hot water in the pex. Then run a different loop to the space heating system. unless I'm missing something there is...
09-29-11, 02:18 PM
Forum: Conservation
09-23-11, 03:10 PM
strider3700's energy use tracking
I had been holding out hoping the forum tracker would get implemented and usable soonish but I'm just going to go ahead and create a thread instead.
My house is 2400 sqft on two levels with the...
09-16-11, 11:33 AM
09-13-11, 05:09 PM
Forum: Conservation
08-04-11, 05:32 PM
at my old house I had an older fridge (early...
at my old house I had an older fridge (early 90's) that had exposed coils on the back. It seemed to run a lot and I noticed it at night when the rest of the house was quiet. Since I had no money ...
07-15-11, 08:41 PM
Forum: Wind Power
05-01-11, 07:28 PM
02-26-11, 06:13 PM
Forum: Lawn and Garden
01-21-11, 12:44 AM
01-11-11, 02:20 PM
Forum: Conservation
12-16-10, 10:08 AM
