09-25-19, 11:59 PM
09-25-19, 10:28 PM
10-06-18, 09:01 AM
made a tube in tube water to R22 exchanger
36mm inside diameter PVC plastic pipe carries water
Inside the PVC pipe have 18 mm diameter coper pipe with R22 inside.
25 meters length = ...
Forum: The Billiards Room
08-12-18, 11:52 AM
02-13-18, 04:44 PM
Made it!
It took me a long time, but it's done. Whew.
What a great thread and resource for the DIY experimenters out there.
I found that the "Closed-Loop/Ground-Source Heat Pump Systems - Installation...
11-13-17, 01:38 PM
06-13-17, 07:34 PM
So this evening, I was able to drop a 3/4",...
So this evening, I was able to drop a 3/4", 100psi hdpe ubend into one 90 foot hole.
Here is the fusing unit that showed up. The sockets are metric, but I was mainly interested in cheap easy heat....
05-25-17, 05:30 PM
AC_Hacker and other contributors
Thanks for...
Thanks for all the good info. I just finished reading p46 of the 193. Thanks for the link to the Geothermal Heat Pump Design Manual on that page. Lots of good...
04-09-17, 03:40 AM
Inverter multi-split with a hydronic zone?
I recently completed my first install of a 2 zone Pioneer multi split in my suite. Painless install. No problems.
I was talking with a close friend this evening about it. He has a little...
Forum: Conservation
02-18-17, 12:12 AM
Commercially available heat pump based HRV
Great Idea, but the Europeans are way ahead of us on HRVs.
Nilan, a Danish company makes a commerically available residential HRV that uses both passive heat exchange and active heat exchange. ...
02-09-17, 03:31 PM
5 Ton GSHP Build
Its been about 4 yrs but probably more than double and north of $3k. for the season
I checked the loop temp and incoming 5 Deg. C. and return 2 Deg. C
Randen
01-16-17, 09:20 AM
IOT heatpump controller
Sadly my old Roca heat pump compressor died.
Fortunately my local scrap man turned up for a pickup and had a mid-size Daiichi external unit in the back of his van. I persuaded him to part with it...
Forum: Conservation
12-18-16, 02:21 PM
Forum: Appliances & Gadgets
12-16-16, 12:00 PM
Forum: Tools
11-10-16, 01:03 PM
Google Play has one called Sunrise alarm.
Features:
Sunrise Alarm" calculates the exact sunrise time based on your location and wakes you up at sunrise.
Other Features :
- Alarm Tone option...
11-09-16, 08:45 PM
Forum: Renovations & New Construction
10-29-16, 10:45 AM
10-28-16, 04:13 PM
The tiny amount of insulation used in the US...
The tiny amount of insulation used in the US building industry is amazing from a European perspective.
In Europe nobody would consider putting less than 150mm of PUR insulation beneath a heated...
10-26-16, 02:05 PM
Forum: Solar Heating
08-28-16, 11:27 PM
08-28-16, 12:14 PM
Help needed incorporating Solar collectors
For years I have been wanting to use the suns energy to heat and power my home. I have read countless stories of people here and elsewhere adding energy wise equipment to improve their home and...
07-28-16, 10:19 AM
Forum: Conservation
07-21-16, 04:39 PM
07-21-16, 03:35 PM
How deep is the frost line?
Found this. Seems like it might be useful info for a GSHP HX or drainage etc..
www.soundfootings.com (http://www.soundfootings.com/pdf/US_Map_Frost_DepthAVG.pdf?loc=interstitialskip)
07-11-16, 11:05 PM
