Forum: Appliances & Gadgets
08-14-20, 06:19 PM
My Weller 140/100 came with a molded carrying...
My Weller 140/100 came with a molded carrying case and extra tips. That makes it even handier. I think I bought it it at Lowes. It will handle 10 AWG with ease. My Weller 20 and 35 watt easily gets...
Forum: Tools
10-08-19, 06:43 PM
04-30-17, 09:35 PM
VAE is not modified Latex but a closely related...
VAE is not modified Latex but a closely related polymer.
Latex and acrylic polymers will form a barrier when they dry. That causes delamination. As long as either or both are overlaid while they are...
02-12-17, 06:44 PM
Forum: Other Improvements
11-04-16, 12:59 AM
MPPT uses a table that has volts vs amps. When...
MPPT uses a table that has volts vs amps. When the wind turbine reaches a specific voltage, it matches the amps in the table. So the table controls amps and volts going out. The volts and amps are...
Forum: Renovations & New Construction
10-21-16, 10:23 AM
The mixing operation.
Polymer modified...
Polymer modified portland and sand are added to the mixer from 5 gallon buckets and mixed with eps from the large white bag hanging above the mixer.
The lift is made from...
Forum: Solar Power
12-29-14, 07:08 PM
Forum: Wind Power
08-29-14, 09:03 AM
Wind turbines never go on a building. The...
Wind turbines never go on a building. The harmonics can literately shake the bricks out of the wall. They can also cause eerie sounds at all times of the day and night. All the wind experts strongly...
Forum: Solar Power
07-10-14, 07:56 PM
Forum: Solar Power
07-09-14, 10:18 PM
I agree with Doax.
If you want to be sure,...
I agree with Doax.
If you want to be sure, take it out and charge it with a good battery charger. Wait 3-4 hours and check the voltage.
My golf cart batteries float at 13.85 volts while the...
03-04-14, 10:46 PM
Forum: Solar Power
02-18-14, 01:23 PM
Forum: Solar Power
02-18-14, 07:02 AM
Cost? about $3400 before rebates.
During...
During daylight, it should run everything except the electric hot water tank. But for now, I'm running lights and electric heaters in the winter and an air...
Forum: Lighting
10-08-11, 07:33 PM
