11-15-22, 10:32 AM
Hello Eco-Renovators
Thought Id give you a...
Thought Id give you a up-date on the DIY 5ton shop ground source heat-pump. It is Nov. 15/2022 and -2 Deg C outside with snow flurries. A couple weeks ago I had moved the...
02-15-22, 05:52 PM
Forum: Tools
02-04-22, 10:43 AM
09-10-21, 05:57 AM
I finished the heatpump build, pressure tested...
I finished the heatpump build, pressure tested with CO2, vacuumed it & filled it with propane, then turned on the heatpump for the first time yesterday!
I charged it with the pump on, aiming for...
Forum: Product Reviews
07-16-21, 07:22 AM
Forum: Tools
05-18-21, 06:51 PM
Forum: Tools
05-11-21, 04:36 PM
Forum: Tools
04-10-21, 08:30 AM
Forum: Tools
02-04-21, 08:08 PM
Forum: Tools
02-03-21, 08:34 PM
Forum: Appliances & Gadgets
12-07-20, 01:39 PM
11-26-20, 06:21 PM
Forum: Solar Power
10-26-20, 05:07 PM
Finally up and running
I rebuilt my old crappy garage and reoriented the new one for full southern exposure. Took a while to get everything up and running because I was doing everything myself (except the final wiring...
Forum: Solar Heating
10-20-20, 08:07 AM
Forum: Conservation
09-27-20, 07:08 PM
08-19-20, 11:21 PM
Forum: Solar Power
08-03-20, 08:30 PM
I posted about our PV system and electric LEAF...
I posted about our PV system and electric LEAF back in 2017, and thought I'd update a bit. In March we bought a newer used Leaf, a 2017 to replace our 2013 which we sold to one of our sons. My wife...
Forum: Solar Power
08-03-20, 07:48 PM
According to my expenses that I track through...
According to my expenses that I track through Mint.com in 2017 I spent $2,098 on gasoline and maintenance on my two gas vehicles (2009 Honda Pilot, and 2013 Hyundai Sonata) and that doesn't include...
Forum: Solar Power
08-03-20, 06:06 PM
***UPDATE 3 years later***
In late July 2019 I...
In late July 2019 I added an additional 3,600 Watts of panels so now I have a 9.98 kW solar array and the power production is fantastic! If you'd like to see a YouTube...
Forum: Conservation
07-22-20, 08:34 AM
Anyone working to Off Grid
Its time to make a couple upgrades to the 20KW inverter. 2 items need some improvements:
The small pump motor thats being powered by PWM supervised by a thermistor in the liquid cooled heat sink...
Forum: Solar Power
07-05-20, 02:48 PM
Piwoslaw's 2.7kW PV system
After years of thinking, reading, wanting, etc., we finally made the move!
Polish government created a financial incentive for PV systems, where homeowners can get up to 5000PLN (over 1100EUR) back...
05-17-20, 08:20 AM
05-06-20, 11:46 AM
Refurbishing old solar hot water panels
Its been quite some time, but years ago I got 10 solar hot water panels (https://ecorenovator.org/forum/showthread.php?t=1251) from BenNelson. They had been sitting for quite some time with the...
05-06-20, 08:44 AM
05-02-20, 12:38 PM
Emporia Vue Energy Monitor
Been looking for a way to monitor power use and found that unitS with logging get expensive quick. Then I found the Emporia Vue. $100 gets you 2 200amp CTs, and 8 50 amp CTs as well as cloud based...
