Old 02-09-22, 03:12 AM   #1
nickchapman
Question Semi Flexible vs Rigid
Im hoping to build my own DIY solar kit and in my research I've been seeing semi-flexible solar panels crop up a lot.
The project will eventually be for my VW camper but I want to get my head around the solar tech available first before I install it.
I have a long way to go and a lot of research to do but initially, I'm wondering if someone with experience in this stuff could outline some of the practical differences between semi-flex and rigid panels?
What are the benefits of using rigid instead of semi-flex?
Are there any issues with semi-flex that make them hard to work with?
nickchapman is offline   Reply With Quote
Old 02-09-22, 02:30 PM   #2
Aside from the mounting differences, rigid panels are going to be more efficient.
nickchapman (02-10-22)
Old 02-10-22, 03:04 AM   #3
nickchapman
Thanks.
Ok so mounting differences seem logical - this makes sense.
It also makes sense that rigid panels will be more efficient.
I'm still trying to visualise the bend of "semi"-flexible panels though. How semi is "semi"?
I have found online for example that Sunpower panels can bend up to 30°, e.g. the SPR-E-Flex-50
But, I would expect that would be affected by the length of the panel? i.e. would the longer 110w be able to bend more?
Old 02-10-22, 03:07 AM   #4
nickchapman
I'm just trying to figure this out as my camper has a curved roof, I want to make sure I'm barking up the right tree!
Also, I'm curious to know if that 30° is a bend length ways or width ways?
If you install with a bend greater than 30°, would it affect performance, efficiency or life-span?
Old 03-04-22, 08:31 AM   #5
nickchapman
So just as an update, I went ahead and bought the 50W SunPower panel - https://envirobuy.com/50w-solar-pane...urved-surface/
I can confirm that there is some bend!
lol ok so the bend is more flexible than I thought, but it still has a level of brittleness to it.
Like, it feels as if it can bend, but shouldnt, if that makes sense?
The best way I can describe how it handles is like a large bendy piece of circuitry.
The bend is enough for my camper and I'm hoping to get on with install in the coming weeks.
Old 03-04-22, 03:18 PM   #6
dguzzi
Let us know how it works out. I like these kind of projects! Pictures please!
dguzzi is offline   Reply With Quote
diy solar kit, rigid, semi-flexible, vw camper
