02-19-10, 02:10 PM | #1 |
Home-Wrecker
Ben's Solar Hoop House
Hey Everyone!
A friend of mine has a conduit bender specifically designed to bend standard 10' long conduit into a 6' half circle. I stopped over, and he showed me how to use it. (Thanks Rob!) I bent up 9 conduits to use as supports for basic little greenhouses. I simply pounded a stake into the ground to make a hole, then put the conduit's ends into the holes, the cover with construction plastic. One hoop house is done so far. I propped up the supports for the other, just to show how it will look. I hope to do two more hoop houses this weekend. Photos below! -Ben MobileMe Gallery
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
02-24-10, 03:49 PM | #2 |
Very good idea, Ben. Starting early this year!
