Old 06-18-13, 01:52 PM   #231
michael.skov
Default mtm tracker whit relay
I will interpret your silence so that you do not want to help others
michael.skov is offline   Reply With Quote
Old 06-18-13, 03:07 PM   #232
I had problems connecting to the server yesterday..
Anyways, MTM is a one man company and the owner asked me not
give the circuit diagram to anyone. He wants to sell products.
(He gives board owners a schematic diagram for their own use. Not to be shared).
Giving someone a picture of the bottom of the board, amounts to the same thing.
The circuit posted above using an LM339, is almost identical to the MTM board.
Schematic for Solar Collector Sun Tracking, Richard Gideon shares solar technology, Phoenix Turbine Builders Club Developer of the Month
But it has controls that might allow it to be set up, so it doesn't chatter the relays to death, like the MTM design.
Take a look at it.. It looks like a better design to me.
I just don't like using relays for this type of application.
Without a really good controller design, the relays won't last.
Old 08-02-13, 05:12 PM   #233
Robaroni
Robaroni's Avatar
Default Dump loads
Originally Posted by jeffharbert View Post
Xringer: The first iteration of my project will be grid powered. I'm also thinking that single-axis tracking will be sufficient - I'll just set the tilt to match the winter sun angle.
Thanks for the link to the 120w panel. I eventually want about 2500kW of solar panels, 1500w-ish wind generator, and gridtie inverter. We bought a house on a cleared acre just before this last Thanksgiving. I also have plans to build a two-story 24x30 detached shop/garage this summer.
On the subject of dump loads, I've always thought it would cool to have a programmable dump load controller that could route the power to a number of different things - vehicle engine block heaters, a domestic hot water heater, hot tub heater, etc. This way that surplus electricity could be put to some really good use. I don't know that such a thing exists, but maybe some quality time spent with an Arduino would do the trick.
Guys,
Before I got the first intertie I had thought about a dump load with a transfer switch. My thinking has changed now. First my batteries are strictly for back up if the grid goes down. Why use batteries when my intertie/off grid system sends excess power (after all my dedicated breakers are serviced) back to the grid. If I want to run a small heater all I have to do is plug it in. My system will power it and if there's excess send it back to the grid. No relays, no dump resistors, etc. I think this intertie/ off grid setup is the best way to go, you never lose a watt of power, if you don't use it you sell it and your batteries last a really long time.
Xringer,
Looks like a neat project! How many modules are you running on that dish, what's the square footage?
Rob
Old 08-03-13, 09:06 AM   #234
mejunkhound
Just noticed this thread.
Thought at first you were going to coat the surface of the dish with aluminum foil or surplus mirror pieces and build a concentrator, then saw you using it just for one-axis tracking.
If you decide to try a concentrator and 2 axis tracking, the link below is a unit I helped build that could give you some information of the thermal aspects of keeping a concentrator cool.
http://www.stretchedlensarray.com/Papers/SPS600V.pdf
Old 08-03-13, 09:15 AM   #235
Robaroni
Robaroni's Avatar
I see where people are using Sterling Engines off concentrators now at some decent efficiencies.
Rob
Old 08-03-13, 12:49 PM   #236
Originally Posted by Robaroni View Post
Xringer,
Rob
There are four 125w panels mounted on it. Don't know the sq feet..
It keeps my battery bank charged and helps heat my DHW tank..
Old 08-03-13, 01:22 PM   #237
The reason I wanted to convert my Radio Astronomy dish to solar tracking, (see plot of galactic core).
was mostly just because I had this nice polar TVRO mount.
Didn't want to scrap it. It's got a certain cool factor, if you are a Ham..
2-axis for solar tracking is pretty much a waste of money.
Since you need to inspect the mount every month or two anyways,
why not take an extra 35 seconds to tweak the elevation?
You don't have to take my word for it, just ask people who have been using trackers for a few years.
Since the price of PV is dropping nicely, there is really no need to track the sun.
Just add more PV for the same money/effort and get the same end result.
The best part is no moving parts. Chance of failure drops to near zero.
Not a lot of maintenance needed on a fixed mount PV array..
If it's on the roof, you might want to try pulling the snow off..
I did that when I had solar hotwater on the roof, many years ago.
Name:	core hydrogen.jpg
Old 08-03-13, 04:13 PM   #238
Robaroni
Robaroni's Avatar
Xringer,
Yes, I would say modules on a roof - not the best but since I got the system for free and had a time limitation to get it in, a roof mount system was the best solution for me. I've been up clearing snow. It takes about 20 minutes and gets me out in the winter which is important. The front modules just about clean themselves especially at the winter angles my modules sit at.
I think if I had 4 modules I would probably use a tracker but with 8 modules and over 100 sq/ft of area the logistics got very complex very fast.
Ditto on the dual tracking system, azimuth just isn't that important.
Rob
electric, solar, tracker
