Old 12-22-09, 05:31 AM   #1
Default Heat accumulator
I'd like to share something I recently found out about how my local power plant uses a new method for raising its efficiency, thereby reducing emissions. But first some background.
Most of the power plants in my climate zone are geared towards producing heat, electricity is a by-product. Of the four power plants in Warsaw only two generate electricity, the other two are shut off at the end of each heating season. The heat feeds the city's warm water network, providing heating for most of the high-rise apartment buildings during the winter, and warm water in the faucets year round. This is more efficient than local, distributed heating. One of the downsides is that it's very hard to adjust production when demand changes hour-to-hour. Most of the electricity is needed in the morning and evening, with a dip at mid-day and a minimum at night. On the other hand, heat production is needed most during the night. Some power plants have extra furnaces that get fired up when demand goes up, but this takes around 3 hours and wastes lots of fuel (almost all power plants here are coal fired, but more are building biomass furnaces). When generating heat at night, the power plant can generate lots of electricity at almost no cost, while during the day the situation is reversed.
About 1-2 years ago the largest power plant in Warsaw decided to add a heat accumulator, already in use at many Skandinavian plants. It's basically a huge thermos which gets warmed up with waste heat during the day, relieving the night load. Or it can be heated at night the help generate electricity in the day. This is a VERY simple setup: just a 47m-high cylinder, 30m in diameter, holding over 30.000 cubic meters (30mln liters) of water. No extra machinery or heat exchangers, just an extra valve. Its heat capacity is 1300MW(thermal). The cost was about US$17mln. I can't find much info on it, nothing on how much it actually saves, but I did find out from an insider that the power plant is very happy with it. So much so that other plants are planning on building something similar.
On a smaller scale, I've read that water-based household heating systems sometimes employ an insulated buffer tank to collect heat when it's available (solar) or cheap (night tariff). I belive that the rule of thumb is around twice the volume of water in the pipes and radiators of the house.
On an even smaller scale, the genII Prius has a thermos for storing engine heat.
Old 12-22-09, 07:01 AM   #2
Good idea. It sounds like it should be pretty cheap to implement (vs the savings it generates). That is a BIG thermos though.
Old 11-25-10, 04:04 AM   #3
I found a thread on heat buffers (heat batteries, accumulators) on a Polish builders' forum. The thread's author, Adam_mk, seems to know quite a lot, and since this is really interesting, I've translated its essence for others to read. I've only condensed the first post, with some information from later posts, but if someone wants to go through all 160-something pages (with 60 posts per page ), then they can try it through google translate. Thanks to Adam_mk for starting the thread, and thanks to many others for adding information and pictures of how they built their own buffers.
The philosophy behind a heat buffer or heat battery is to "charge" it with thermal energy whenever it is cheaply available, and use it when it is needed. The more energy that can be stored for a longer period of time, the better, so the buffer has to be large (1000-2000 liters of water, 1.5-2.5 tones of thermal mass) and very well insulated (5cm of mineral wool with a layer of aluminum foil, then 30-40cm of styrofoam).
Most commercially available hot water tanks don't have a very efficient design, the internal heat exchanger is coiled around the perimeter. The lowest coils can still give off their heat, but the upper coils sit in the heat released by the lower coils, which reduces heat exchanging dynamics. That cloud of water heated by the coils rises along the walls to the top, while cooler water falls down the center of the tank. Between these two streams of water is an area of turbulence, causing part of each stream to mix with the other. This leads to the hot water not being as hot as it could be, while the cooler areas inside the buffer are warmer than they should be.
The best remedy for this is a buffer that keeps water at different temperatures in different layers, without mixing. Consider the following design:
The coils from a heat pump or solar collector are at the bottom of the tank, and spiral down and outwards. This places them in the coolest region of the buffer, so more heat can be extracted. The water which recieves that heat can rise without washing over more coils, so those are also sitting in cooler water. The rising warm water is collected by a funnel and goes up the middle of the buffer inside of a "chimney", which delivers the hottest water straight to the top, pushing cooler water down, but with no mixing along the way. The chimney is perforated from about halfway up, with the holes becoming gradually larger towards the top. This allows warm, but not hot, water to exit the chimney at the height (level) where water of that temperature is collecting, pushing cooler levels down, but not interfering with the warmer levels above.
Water for domestic use (sink, shower, laundry) is warmed in a coil on the perimeter of the tank. Entering at the bottom, the coils move closer together as they work their way up. Notice that this design qualifies as a double-wall heat exchanger between potable water and the freon or glicol filled coils from the solar/heat pump system.
When heat pump or solar heat is not available, the buffer can be heated ("charged") with a furnace, stove or fireplace - cool water is taken from the bottom and hot water returned at the top. This allows heat from a fireplace/stove to be saved for later, and allows the furnace to always run at its maximum efficiency, instead of having to turn on often for short runs at a lower temperature.
Somewhere at the bottom of the tank there should be 2-3 electric heating elements (1500 watts each) to charge the tank when other heat sources are not available and when electricity at night is cheap.
Using hydronic floor heatering, with its large surface area and low temperatures, will allow much more heat to be used from the buffer, as opposed to normal radiators which require higher temperatures.
One more secret:
All of the inputs and outputs are curved in such a way that water that is leaving/returning to the tank causes the whole mass of water inside to delicately turn in one direction. This buffers the entering/exiting water's kinetic energy without causing turbulence and mixing between thermal levels.
For this design to work well, it should be taller (at least 6ft/2m) than wider (27-35in/70-90cm), so that each thermal level has room to store energy, while the area between levels is minimal.
A heat battery with 1-2 tons of water is a good start, but can later be expanded if required. Here is a link to the Polish thread on how to connect two or more water tanks for maximum efficiency. Of course, using one large tank would be even more efficient (less total surface area = less heat loss), but space or financial restrictions may not allow that.
If you are trying to store the most heat in the smallest possible space, then you can look at using phase change materials to increase capacity. Paraffin wax is a by-product of the oil refining process and many refinaries have more of it than they can get rid of. This material is very good, since its melting point of around 55-60°C is the temperature that you'll usually have in your heat buffer, and its volume doesn't change enough to be much of a problem. The paraffin tank should have lots of small diameter tubes (more tubes = more surface area = better heat exchange) for water to deliver and recieve heat. Here is a link to the Polish thread.
Heat buffers of the DIY variety are the best: they are individually tailored to each house's energy needs and space limitations, and they are much cheaper than a commercial alternative. People who have made one (info in the thread linked at the beginning of the post) said it costs around 5000-6000PLN (around US$2000), while a commercial tank costs almost twice as much and is less efficient. A homemade heat battery is usually adapted from a large commercial tank, or from a pipe segment with custom endcaps welded (bolted) on. The metal can be normal steel, around 4mm thick. Commercial units are often made from stainless steel, but this only raises the cost and makes it harder to weld, while the "stainlessness" is never needed: you won't have a nice shiny cylinder to look at since it'll be under at least 35-45cm of insulation, while on the inside the surface will get covered with a layer of scale after the first time it's heated to 80°C, after that the water will contain no gasses or minerals, so there shouldn't be any corrosion.
Check out AC_Hacker's post for some great links to similar buffers.
Old 11-25-10, 04:18 AM   #4
Here are pictures of what the hp/solar coils should look like:
It is actually two coils, plumbed in parallel, one on top of the other. The spirals are 15mm copper tubes, the common input/output is 22mm.
Here is the coil fixed to the bottom cap. Notice the heating element inside the coil. Two more elements will be installed (arrows).
The chimney (before perforating the top half):
The heat exchanger for domestic hot water. Notice how the coils get closer to each other near the top.
The inside of a (partailly completed) heat buffer. Notice the how the inputs/outputs will cause the water to rotate. The direction of rotation should be tailored to the Coriolis effect in your part of the globe.
The Following 3 Users Say Thank You to Piwoslaw For This Useful Post:
abogart (02-04-12), osolemio (06-16-11), strider3700 (11-25-10)
Old 11-25-10, 06:15 AM   #5
The heat buffer is a great place to dump excess heat from air conditioning or ventilation, to use later as hot water or heating. If more than one heat source is used (not counting furnace, stove, fireplace, etc.), then more than one set of coils at the bottom of the tank may be needed. The most efficient way to place them is one under the other, but with a second funnel between them, going to a second, smaller chimney. The cooler of the two sources (heat pump) should use the outer chimney, while the hotter (solar) should use the inner chimney to send its heat to a higher level.
Electric heating elements can not charge the buffer using cheaper night tariffs, but can also be a dump load for wind, hydro, PV, etc.
It's good practice to put 4-8 temperature sensors inside the buffer at different levels to know how much energy is stored. Only one sensor is not enough, since heat is stored in different temperature layers, so it's possible to have a thin layer of 80°C at the very top while most of the rest will be around 50°C, or to have 80°C in the top 70% of the tank. In the latter case the buffer has much more stored energy.
Old 12-02-10, 10:28 AM   #6
osolemio
Hong Kong
Very interesting!
I have a 1000 liter tank (~300 USG) which is made for this already, from the Austrian Okofen (US dealer is located at oekofen-usa dot com). The one I have has two heating circuits, a solar heat exchanger and hot water is flow-through in a stainless steel pipe, not "sump water" (always fresh water, both hot and cold).
The solar heat exchanger is at the bottom, but it has a "chimney", an internal vertical tube connected, with holes in it. The hot water in the buffer water will exit from this chimney at exactly the level where it does most good, as the density of the water changes slightly with temperature. If there is plenty solar heat, it goes to the top to give a good temperature for the hot water supply, leaving the bottom less heated for times where there is less heat from the solar panels.
Old 02-20-11, 09:46 PM   #7
Indyplumber
I have a question about storing the extra heat generated during the day. What is the best commonly available medium to use? I have a basement and crawl space to put something in but nothing large. Would a 4ftx4ftx4ft concrete block, very well insulated and buried in the ground, with PEX tubing running through it work? Can't really have a
1-2k gallon tank anywhere. I understand the efficiencies probably wont be good but I want to make a system as cheaply as possible using common materials.
Indyplumber is offline   Reply With Quote
Old 02-20-11, 10:55 PM   #8
Best can have many meanings.
You might want to find out what "specific heat" means, it might help you to answer your question.
Old 02-21-11, 01:44 PM   #9
I've read about storing heat in phase-change materials.
One idea to keep automotive engine coolant warm was a phase change salt, see this thread over at EcoModder for more info.
Another idea, on a larger scale, is to use wax (paraffin). Basically, you need a well insulated container with lots of small tubes crisscrossing, then you fill that up with the right type of wax. Paraffin is a by-product of oil refining, I read somewhere that many refineries would be glad to get rid of their extra paraffin. Make sure you get the type with melting point around the temperature you want to keep your heat stored. Once everything is working, water flowing through the tank will be warmed up - you'll see it's exit temperature gradually decline, then flatten out for while (melting temperature of the wax), then decline again. The rate at which heat is tranfered from wax to water (or water to wax when charging) depends on how close together the tubes are, how much surface area they have, etc.
Parafin tanks work great when paired with a heat buffer.
I can't remember the exact numbers, but I think that a paraffin tank can store something like 30%-80% more heat than a water tank of the same size. If anyone is interested I can try to find more info.
Old 02-21-11, 04:24 PM   #10
Clev
Wannabe greenie
This topic was recently brought up on another group I participate in. We were discussing using a similar setup to heat a tank of paraffin using engine coolant, and then using the tank to maintain the temperature of the living space in an RV overnight without using fuel.
The only major downside brought up about paraffin was that it's flammable. With that (and expansion) well-managed, it seems like a workable idea to me.
Clev is offline   Reply With Quote
