Old 09-26-20, 09:54 AM   #1
Default Gasoline powered wood chipper
Well I got the small DR chipper shreader.
The electric one works. Problem is when I cut down one smaller 15 foot tall tree it takes me at least 40 minutes to feed all the little sticks and twigs into the electric wood chipper. A big tree takes like 2 hours.
For me everything greater than 1 to 1.5 inches in diameter is fire wood so I'm not trying to mulch everything.
The smallest 6.5hp 208cc DR should be fine.
Old 09-28-20, 12:55 AM   #2
u3b3rg33k
DR makes good stuff, but not a big fan of the B&S engines. our chipper is the 18HP model (eats a up to 4x4s). well it was, the B&S motor wore out and it's now a 20HP Honda. nowhere near the hours on it as the kawa powered brush mower and that is still running strong.
that said for small occasional use you'll get plenty of use out of it.
Old 09-28-20, 09:00 AM   #3
Yeah I definitely don't want to chip something 4x4. The biggest wood I would chip is rotten wood. It's light as a feather and will catch fire from the slightest spark.
If I grind those into dust they shouldn't be a fire hazard any more.
What happened to the Briggs and Stratton engine?
It seems like the wood chipper application is hell on motors.
If I kill this motor I will try to replace it with the biggest single phase AC motor I can find that will fill in all the important holes.
I'm wondering if it's a 56TC frame foot print.
I can see blades in the chipper and it looks like hammer mill hammers and a shreader blade down inside the shredder.
Old 09-29-20, 01:21 PM   #4
u3b3rg33k
the B&S engine just wore out. I think it was the rings/cylinder. had it happen on the log splitter, too (also a B&S motor). mind you these things had what would amount to light commercial use for the better part of a decade. their higher end stuff has engines with real oil pumps and filters vs the splash lube of the cheap stuff.
Old 09-30-20, 12:05 AM   #5
Yeah I have a Kohler v twin riding lawn mower from like 2008 that's had the hell beaten out of it. The Kohler engine uses an oil pump and filter.
Old 10-14-20, 10:22 PM   #6
Got a big pile of wood chips now and I'm thinking let them dry out and burn them in the coal furnace.
Old 10-16-20, 09:37 PM   #7
u3b3rg33k
big boy pellet stove?
Old 10-19-20, 03:02 PM   #8
It's just a coal furnace that you shovel coal into.
Old 10-19-20, 09:25 PM   #9
u3b3rg33k
well dry wood chips are basically coal-precursor lumps so same same right?
Old 10-20-20, 01:15 AM   #10
Yeah wood just burns really fast compared to high grade coal.
Daox (10-20-20)
wood chipper
