Old 07-31-20, 07:26 AM   #1
jlaw
Learning to save
Default Low Cost Water Mister for AC
I put together this water mister for my AC/Heat Pump. Being put off by the cost of a ready made unit I did some research and put this together from Amazon. I will include photos and links to the products. I was fortunate that I had a hose bib next to my unit, You will need some zip ties and a few ferruls for the fittings or buy what you need. This is the water filter-https://www.amazon.com/gp/product/B00HYXR24S/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1. Water valve, 24vac hooked to fan wires-https://www.amazon.com/gp/product/B081N6YJM1/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1. Mister kit-https://www.amazon.com/gp/product/B07G33MVJ1/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1. Total cost $52.92. Plus a few misc. items. Works well for me.
ID:	9024   Click image for larger version
ID:	9025   Click image for larger version
ID:	9026   Click image for larger version
ID:	9027   Click image for larger version
ID:	9029   Click image for larger version
ID:	9030   Click image for larger version
ID:	9031   Click image for larger version
jlaw is offline   Reply With Quote
The Following User Says Thank You to jlaw For This Useful Post:
the.taiwanist (08-01-20)
cooling, heat pump, mister, water
