Old 09-25-19, 12:59 PM   #1
plaine300
Default Hanwha array output variation question
Hello,
Just found this forum and thought I'd ask a question. We recently activated our 2 arrays made up of (28) Hanwha Q CELLS Q.PEAK DUO Q.PEAK DUO-G5 315 modules. I've attached a screen shot showing the output so far today, for example.
For the most part, they're all performing consistently. Except for one guy shown as 923 in the West array as shown in the attachment. My question is, is this a normal variation or is this a bad panel? I'm not totally sure what variation to expect, so before I hassled our installer, I thought perhaps someone here may lend some insights.
Thanks for any thoughts.
Name:	Image 9-25-19 at 1.51 PM.jpg
plaine300 is offline   Reply With Quote
Old 09-25-19, 03:42 PM   #2
Where in SC are you?
I would not be worried about that. Does than on get any shade? I had one performing not as well and it have a big bird feather on it.
Dirt can make a difference or bird doo.
Here is mine you can easily see the three micro inverters that were replaced under warranty.
The bottom array was put in a few months later.
