#1 |
![]() I did a fair amount of research looking at build /buy a CNC table. I was close to making one but in the end buying just made more since.
I would have had more money in building one. I have a lot to learn just in software to use it. It will be about 8 weeks before I get it. They build to order and they just had a sale. I am getting a water table to keep smoke down and warping to a Min. It has torch height control. I will be using my new plasma cutter on it. I will have to buy a CNC port board and a machine torch. Delusional Designs https://www.delusionaldesignscnc.com...ter_Table.html I am not sure where our focus will be yet. I will be selling some stuff I cut but I would like to keep the finish and painting part to not much as this is a side business. I am probably limited to ½” and under cuts. I will add an extension to the table to all put a 4’x8’ sheet on the table. If we like doing this we will buy a table extension to expand this table to 4’x8’ table.
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 07-09-19 at 08:33 AM.. |
The Following User Says Thank You to pinballlooking For This Useful Post: | Fordguy64 (07-09-19) |
#2 |
![]() Have you used it yet?
#3 |
![]() I actually canceled this one and I am going to order the next model up from this one that uses linear rails better software. It will let you continue from the spot you had a issue. I am going to get the 4 x 8 table as this one is harder to upgrade later. I was able to get a machine torch off Ebay that had been only used once for a killer price. That will help with some costs. But I have to buy a bigger ticket compressor.
#4 |
![]() Sounds fun. Do you have lifting equipment? A 4x8 sheet of metal can weigh a lot.
#5 |
Need More Eco
![]() Sweet dude!
I have a 4x14 plasma cam setup with a Hypertherm Powermax 45 on it. What cutter are you planning on running? If there’s anything you think I might know feel free to hit me up, but as I’m sure you already know Jim Colt is THE authority on small CBC plasma setups. |
The Following User Says Thank You to dremd For This Useful Post: | Daox ![]() |
#6 |
Need More Eco
![]() I see you are interested in a water table, unless where you are venting to is smoke critical I wouldn’t. I had a water tank in mine and ended up pulling it out because it was a pain to clean and only helped so much.
#7 |
![]() My subcompact tractor has quick attach pallet forks. It can lift the steel. I also have a hydraulic lift table that I move pinball machines around with that can lift 1,000 pounds.
The Following User Says Thank You to pinballlooking For This Useful Post: | Daox ![]() |
#8 |
![]() Yes I getting a water table. The new one I am ordering will come fully assembled. I have a thermodynamics 60i I just bought a 50' machine torch for it.
#9 | |
![]() Quote:
#10 |
Need More Eco
![]() Originally I cut 20, 16, and 12 ga steel.
Now it spends its days cutting.040 ,080, .125 aluminum mainly in 5052 Typically daily cut time is only around 2 hours with run time closer to 2.5 hours. Typically 5 days a week, but that varies by season. |
