Old 10-02-18, 08:17 AM   #1
SentinelAeon
Default laptop plastic cases (re-use/repurpose ideas?)
I have plenty of laptop cases at home and i am wondering whether to throw them away or do something nice with them. 1 idea is to melt them in oven into nice plastic pieces and use them for some project. Any other ideas ?
SentinelAeon is offline   Reply With Quote
Old 10-22-18, 12:34 PM   #2
SentinelAeon
No one has any good ideas ?
Old 10-25-18, 08:02 AM   #3
Put stuff in it to store? Are you talking soft cases or hard cases?
Old 10-25-18, 08:24 AM   #4
SentinelAeon
I am talking about a plastic case in which laptop components and screen are in. I took usefull things out, like motherboard, screen, procesor, etc. Now i am left with empty plastic cases. I was thinking about melting them into some usefull pieces, like stand for my drills, etc.
Old 10-25-18, 01:47 PM   #5
I can't imagine doing much with them besides cutting them up for projects, or melting them down as you said.
Old 10-25-18, 02:02 PM   #6
SentinelAeon
I was thinking of melting plastic into ingots that i would later use. The best idea so far i got was simply puting plastic into blender, blending it into fine dust, and after that using the oven to melt it. Do you know of a better idea to do it ?
Old 11-01-18, 12:05 PM   #7
Nope, and I'm not even sure how you would melt them down in a nice fashion to begin with. Do you have plastic working equipment?
Old 11-01-18, 12:11 PM   #8
SentinelAeon
I dont have anything special, but i did melt some plastic in the oven in the past. It was hard plastic that i was able ti blend in a blender, then i put it into glass container that had cardboard mold inside. It worked out fine. BUt it was a lot of work. And it wont work for plastic from bottles - i wasnt able to blend that plastic since it is to soft. And unless it is blended, it wont melt nicely.
Old 11-02-18, 11:01 PM   #9
This guy has beat you to the solution to your problem:
https://youtu.be/8J7JZcsoHyA
Visit precious plastic dot com for the rest of the story.
Old 11-03-18, 07:53 AM   #10
SentinelAeon
Basicly it is very simple, but i would need to make a mill to grind the plastic into small pieces. Oh, and obviously find a good spot to put all that plastic after i melt it
