Old 08-27-18, 03:40 PM   #1
Default Hustler RAPTOR SD 60-in Zero-turn lawn mower added DIY LED lights.
I finally retired my old MTD mower and bought a Zero turn mower. I bought it from Lowes they give a 10% discount for veterans that really helped out. It was had a little lower price than normal also never a bad thing.
I wanted LED lights Hustler sells a kit for LED lights $150.
I went the DIY way. This setup uses the two existing bolts so no drilling necessary.
$29 shipped later and I have some nice LED lights I have used them a couple times and they work great.
I did not mount the switch yet because they have a 30 day return policy and you just never know. Once I get past that point I will mount the switch.
It puts out a lot of light. I was going to go for a bigger light bar but I am glad I went with this one.
LED Lights
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Wiring
Old 08-27-18, 11:37 PM   #2
I added stick on LED strip inside the head light housing on my craftsman mower.
Much better than the two 1156 bulbs. I could barely see anything after dark. Now I can see the difference between tall grass, short grass and rocks.
Old 08-28-18, 08:54 AM   #3
My new mower has the Kawasaki 24 HP V-twin it is know for good power a sipping gas compared to other options.
I can mow in less than ½ the time using ½ the gas I was using with my MTD lawn mower.
The seat springs rub on the steel under the seat makes noise and takes off the paint. I added furniture sliders to the top of the springs.
Nice and quiet and no paint rubbing off. The seat bolts are known for coming loose I added blue Loctite to those bolts.
The first oil change is at 5 hours then next one is 100 hours. I am close to the first one.
Old 08-28-18, 09:28 PM   #4
The cover on the deck like to collect grass and will push off the belt if you don’t clean them out.
I added 4 thumb screws two on each side to make it easy to take the off and clean them out. After the 30 day return period I will cut some holes in them to make easy to blow out the grass.
I have over 6 hours on it so time for the first oil change. I will switch it to Mobil one oil.
Old 08-29-18, 12:44 AM   #5
Use mobile 1 air cooled engine oil, it's SH or SJ rated.
