Old 01-14-17, 05:40 PM   #1
Default More good news: water main and plumbing replacement.
Any one ever see that movie "the money pit". That's kind of what's going on. I have to say if our house wasn't paid off it might not be worth it.
The fresh water piping is in my house is mostly galvanized steel. The problem with galvanized steel water pipe is it usually lasts around 30 to 50 years, well the house is 56 years old.
The addition is from 1980 it has PVC and I'm going to leave it alone.
I want to make a big water main and header. I'm going to try and collect 1.5 inch stainless pipe for this. Reuse it. I usually ignore 1.5 inch pipe when I see it now I want it. 1 inch would be ideal bit I hardly ever see 1 inch at all.
This is food grade 304 stainless that was used for water, milk or whey. I will have to weld these lengths and elbows together.
If I can't find enough 1.5 inch stainless I think I will just use 1.25 inch copper.
Then 3/4 copper for most of everything else.
I like copper. Not a big fan of the plastic stuff.
Old 01-15-17, 08:46 AM   #2
The good news is I'm off to a really good start. I got about 15 feet of 1.5 inch stainless pipe yesterday.
Bad news is it could be up to 2 or 3 months before I see any more and I need around 60 feet.
Old 01-15-17, 09:19 AM   #3
Oil pan,
Stainless steel makes no sense! Expensive, hard to make joints, joints are prone to leakage, joints hard to find and expensive. Welding tedious and welds are prone to cracks.
Look at your choices. PEX is there for a reason. If you need stainless for water purity, then we can have another discussion, but you must have other fundemental reasons for not using PEX.
Respectfully,
Old 01-15-17, 11:42 AM   #4
The stainless steel will cost between $0 and 50 cents a pound. There are no pipe joints. This water and food grade process pipe is butt welded together.
The only time I see this pipe cracked is when it's constantly hydraulic hammered.
There is about 100 miles of this pipe where I work and there are less than a dozen leaks. If it was prone to leaking there would be a few more leaks on 100 miles of pipe.
The only joints I need is a single 90° elbow and I already have it.
I can weld this pipe.
I don't care for plastic line.
Old 01-16-17, 01:27 PM   #5
To fusion butt weld the pipes together you need nice perpendicular cut pipe to butt together with absoltly no gap anywhere arounf the weld joint. Where I work we have a specialized tool for this it's called the George Fitzgerald.
I'm pretty sure I will never own one because they are about $7,000 for a used one and the cheap knockoffs are around half that.
Any pipe I buy from the scrap yard I can take to work and square up the ends on the GF+ machine.
This is going to take a lot of argon.
Old 04-05-17, 08:02 PM   #6
I picked up another 15 feet of 1.5 inch staniless. I am glad I am not in a hurry to get this done.
Old 04-05-17, 09:09 PM   #7
So you are ½ way there not to bad.
Old 04-27-17, 05:31 AM   #8
WyrTwister
Our house was inherited from my parents . It was built in the 1950's , I think . All copper piping . Pier & beam construction .
First I we piled the hot water lines that were buried in the dirt ( under the house ) . That stopped a large leak .
Maybe 6 months latter , large leak in the back yard . Dug that up ( with help from younger son ) and soldered in a repair .
About another 6 months , another water leak . Re-piped the colb water lines in the dirt ( under the house ) . That did not fix the water leak .
That left the water main , from house to alley . Rented a Kabouta Mini excavator from Home Depot , dug the ditch and installed 1" PEX .
Next weekend I rented the mini ex again and covered the ditch up .
The main cold and hot water lines , under the house , were 3/4" . I uses a 1/2" x 3/4" x 1/2" Tee , cut & soldered into the closest run of cold water line . Feeds both directions . With a ball valve before it enters the Tee .
That way , I can turn the valve off , while I am under the house , if I ever have to work on the piping again .
I recommend PEX for the main water line . I ran white 1" . I now have a PEX crimping tool for 1" to 1/2" ( maybe 3/8" ? ) that has only crimped 2 one inch copper " rings " .
The 2 rentals of the mini ex were the most expensive part . The 1" PEX was maybe twice as expensive as PVC . Still , not a lot of $$$$ . The PEX brass fittings / barbs were more expensive than PVC fittings , but only used 2 of them .
If I had it to do over again , I might use red & blue PEX for the branch lines ( under the house ) .
God bless
Wyr
copper pipe, stainless, water main
