Old 10-16-15, 09:47 AM   #1
charlesfl
Default Piping Design
I found a information guide by McQuay on Refrigeration Piping Design Guide for their technicians. It is a pdf file.
http://inspectapedia.com/aircond/AC_Guide_McQuay.pdf
Hope this helps, Charlesfl
The Following User Says Thank You to charlesfl For This Useful Post:
jeff5may (10-20-15)
Old 10-20-15, 05:47 PM   #2
This is one awesome document! Not quite for the beginner, but it is full of practices and methods to follow that serve as a good road map to follow. Novice and experimental system builders should look at this document to improve their quality and success rate. I hope you don't mind if I link people back to this thread.
Copyright ©2000 - 2023, vBulletin Solutions Inc.
