Go Back   EcoRenovator > Improvements > Biofuels
Old 08-28-14, 10:26 AM   #1
Greg
Default Wvo hydronic heat
I have been thinking of this for some time and now I'm building this. My problem is to heat my dog kennel. I have a bit of a different situation of an existing building, the floor is 2 inch lumber. In order to insulate I placed 2 inch blue foam over the floor then strapped with 1x4 and using heat transfer plates under to my pex. Next I went over this with 5/8 ply.
Now for the heat source I have been collecting wvo for some time and prolly have 1500 gal of the stuff. So I'm building a boiler, really a wvo fired hot water tank. After several days of r&d basically setting playing with fire, I'm quite happy with the product. I will now install in a small shed and get ready for the coming winter. Here r some pics. Greg
Greg is offline   Reply With Quote
Old 08-28-14, 10:36 AM   #2
Greg
More pics I can only submit one pic at a time
Old 08-28-14, 10:42 AM   #3
Greg
Here is my turk burner that is powering my wvo water tank. The air is supplied by a 2- 4 inch computer fans, I was finding if I hooked up one fan to the battery and the other to the solenoid thermostat circuit that I got better control of the flame as it cycled from hi to lo
Old 08-28-14, 10:45 AM   #4
Greg
Ok I reinvented the wheel but it didn't exist on the shelf in the stor and it is necessary to light this puppy ,enjoy ,Greg
Old 09-01-14, 09:23 AM   #5
Greg
Default wvo heating
Here is a pic of what i intend to heat with my home made boiler.
Old 09-01-14, 09:26 AM   #6
Greg
Default wvo heating
more pics I got this idea from the wonderful article right here on Ecorenavator.
Old 09-17-14, 08:56 PM   #7
gtojohn
gtojohn's Avatar
Wow! that is playing with fire! I didn't see one in the pictures, make sure you have a TP release valve. Mythbusters have done some amazing house explosions with hot water heaters stuck on with the TP valve disabled.
