#1 |
![]() Recently, I built an audio amplifier based on TI's hybrid digital chipset. It is made mostly from recycled parts (the only parts I purchased just for it are the chipset, terminal block, and switchover relay). It is built in a case from an old 802.11b router and the power supply is from an old laptop. The chipset uses only 1W (one watt!) at normal listening levels. The power supply is actually quite efficient - level 3 efficiency rating. Here's the schematic: ![]() And here's a view of the circuit boards: ![]() P.S. I named it after a celebrity. Amanda Harris ( http://barbiebarbell.com/ ) is known for her incredible power-to-weight ratio and that's what first came to mind when I cranked up the volume (the chipset is capable of over 60W RMS continuous in my testing, which is *VERY LOUD*).
To my surprise, shortly after Naomi Wu gave me a bit of fame for making good use of solar power, Allie Moore got really jealous of her... Last edited by NiHaoMike; 02-08-09 at 07:02 PM.. |
#2 |
Neat stuff
#3 |
Very cool. I wish I knew enough about electronics to do more stuff.
#4 |
#5 |
Welcome to the site Mr. Cheap. If you have a minute we'd love to see an introduction post and you can tell us a little about yourself.
![]() I agree and I am actually working on my first electronic project that I've done in a long time. Check it out on our sister site EcoModder.com. |
#6 | |
Two of the opamps are used as SE to differential converters and the other two are for the power on reset. Here's a picture of the homemade cradle: ![]() It has USB, 12v power, S-video, composite, and line out.
| Thread Tools | |
| Display Modes | |
