Old 09-06-13, 12:41 PM   #1
Default Bugs really like LEDs
Correction: LED Lights Do Attract Bugs. | Energy Circle
I had read somewhere, that LED lamps didn't attract bugs.
Turns out that may have been incorrect..
Old 09-07-13, 09:58 AM   #2
Exalta-STA
What I can say though is that ever since I switched to LEDs 6200 kelvin and 3000 kelvin, I have less bug problems...and this is from someone living in the tropics where a single light can attract hundreds of bugs
incandescent = bug nightmare
CFL = bug magnet
LED = a few strays now and ten
Exalta-STA is offline   Reply With Quote
Old 09-07-13, 03:09 PM   #3
Maybe the side-by-side testing had the blubs too close together?
One on either side of a door? Maybe 3 to 4 feet?
Perhaps the incandescent was pulling them in,
and some of them flew over to the LED to check it out.?.
If bugs really like blue light, this chart seems to be showing,
that a white LED has a lot more blue emitted.
So, the LEDs would be worse than the incans?? Something is amiss here..
Edit:
From what I've been able to find out, warmer colors=less bugs..
So, these 2700k LEDs might be a good choice..
Cree 9.5-Watt (65W) Soft White (2700K) BR30 Dimmable LED Flood Light Bulb (4-Pack)-BBR30-06527FLF-12DE26-1U110 at The Home Depot
Old 09-07-13, 08:53 PM   #4
Exalta-STA
Hi Xringer,
Yes somethings definitely wrong. Ever since I switched to LEDs, the less insect problems I had. I only use the white and the yellows. It replaced the CFLs of the same color.
The CFLs both inside and outside the house attracted spiders, flying bugs, moths, and swarms of flying termite drones...and every insect who had the capability to go near it.
Changing to LED cleared it all up. No insect whatsoever or if there's any, it's just a solitary cricket checking out the door.
Old 09-07-13, 08:57 PM   #5
Exalta-STA
Hey I have this crazy theory, it might be the heat of the CFL and incandescent lights. The old bulbs I had before had so much heat that you can feel it a few feet away. The LEDs i have now are running cool.
Old 09-07-13, 09:30 PM   #6
Radiant heat as felt by humans doesn't seem to travel very far.
I can stand 3 or 4 feet from a 2kW heating element and not feel it.
Since the energy emitted from the heating element, isn't felt at a distance,
it must be getting absorbed by the air. Air gets hot and goes upwards.
Maybe insects have better heat sensors than us?
We are warm blooded, so our skin sensors don't really feel weak radiant heat.
I assume that an insect's body temperature is a bit above the outdoor temp.
Insect thermoregulation - Wikipedia, the free encyclopedia
Or maybe it's a matter of scale. When you are 100 feet from a very large fire,
(Like a forest fire) you can sometimes feel the direct radiant heat.
Maybe they can sense heat at much greater ranges?
To them, a 100w blub might seem like a forest fire..
One other thing just occurred to me. Remember those yellow blubs?
Bug free? Maybe those 2700k LEDs look yellow to insects?
I wonder if the yellow bulbs look too much like a flame to a bug?
If you light a camp fire, it keeps the bugs away. They don't like smoke?
Old 09-07-13, 09:53 PM   #7
Exalta-STA
Hmm yes, the yellow produced in LED bulbs are almost the same spectrum as a flame.
Old 06-19-18, 01:43 PM   #8
I'm not sure if I posted elsewhere on this topic. Maybe I did, but here's what I've learned lately..
After installing some outdoor LED lighting on my garage, I had a real bad bug problem!
The bugs were leaving a large amount of droppings on the fixture and on the green sidling.
The mess was so bad, it took a lot of work to clean up. Soap, brush, water hose & etc..
I Put them on timers and them, but soon went to an IR motion sensor..
They go on for about 5 minutes when motion is detected in the driveway..
Mostly, they never come on during most nights..
For me, this is the only way to use outdoor lighting in this area.. Too much bug poop..
Old 06-20-18, 09:28 AM   #9
Sounds like a prime location to install a bug zapper?
Old 06-20-18, 12:17 PM   #10
Not needed if you use motion sensors. Which I believe provides better security and safety.
Let the bugs go to poop on the LED street lights.
