Old 09-25-12, 01:11 AM   #1
ownerbuilder2012
Aspiring Renovator
Default Chicken coop + Living roof
I just came across this...
A perfect example of how to make the most out of your chicken coop or rabbit hutch.
Not only does it have a living roof, but as it is also placed in a vegetable garden , you can reuse old straw, bedding and droppings as instant compost.
Does anyone have instructions on how this is made?
ownerbuilder2012 is offline   Reply With Quote
Old 09-27-12, 09:57 AM   #2
It doesn't look horribly hard to make. Just look at the picture and make up your own version.
Old 09-27-12, 05:17 PM   #3
S-F
You Ain't Me
S-F's Avatar
I would cover the entire inside of the planter with ice&water or else the coop will have a short life indeed. Or you would have to cook up a good way to drain it
My project:
Old 09-28-12, 11:23 PM   #4
ownerbuilder2012
Aspiring Renovator
You're definitely right, I just need to experiment. I would definitely encounter a problem or two, but it's a challenge worth dealing with.
Old 09-28-12, 11:25 PM   #5
strider3700
EPDM pond liner is used as the membrane under a lot of DIY living roofs. unlike ice/rain sheild there are no seams for roots to work at.
Old 10-03-12, 09:02 AM   #6
ownerbuilder2012
Aspiring Renovator
Thanks for the advice, you're right, why didn't I thought about that. I'll save that on my list of things to buy for this project.
Once again, thanks!
Old 10-23-12, 11:20 AM   #7
Its been a couple weeks. Have you done anything with this?
