Old 11-13-08, 02:40 PM   #1
Default Looking for a temperature data logger
Does anyone know anything about temperature data loggers? I have lots of upcomming stuff that I really want to collect info on and it would be incredibly useful and sometimes necessary to track temperature over time. The units I've googled seem to be quite expensive. Any ideas would be great.
Old 11-13-08, 09:42 PM   #2
MetroMPG
Infrequent noob
I know you don't want to build anything, but...
The Boundingbox Blog Archive Arduino + Temperature
Old 11-14-08, 07:02 AM   #3
Well, that doesn't look too difficult. Except, I've never done work with the Arduino before. Doesn't it require some sort of programming board/interface? I'd also need at least two of these. I'd like at least a two channel data logger, four channel would be better.
Old 11-14-08, 05:24 PM   #4
MetroMPG
Infrequent noob
The *duino has multiple inputs (digital & analog). So you could probably make it run multiple sensors on a single board.
You program it by hooking it up to your computer. The interface is a program you download from their site.
Old 12-03-08, 08:08 AM   #5
Well, after hunting around the duino I think is going to be the way to go. The other options are just way too expensive. Theres nothing that would work for what I want for under $100. I'll post progress on this when its avaliable.
Old 12-05-08, 12:29 PM   #6
groar
X-Frenchy: very
groar's Avatar
I have seen this one (sorry in French, but there is some graphs) :
Enregistreur USB longue durée température et humidité - T°, %RH et point de rosée pour Diagnostic de Performance Energétique (DPE) ou autre - 64.50EUR- achats éconologiques
It saves up to 16000 points with temperature and humidity. You configure the time between the records from 2s to 24h.
Velleman sells in US but I don't know if this recorder is sold in US.
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Copyright ©2000 - 2019, vBulletin Solutions Inc.
