Go Back   EcoRenovator > Improvements > Biofuels
Old 02-11-11, 02:08 PM   #1
Drake
DIY Guy
Default DIY plans for small biomass water heater
Looking into the possibility of supplementally heating water for hydronic with small biomass heater when home.
Old 02-11-11, 04:40 PM   #2
RobertSmalls
RobertSmalls's Avatar
What sort of biomass do you have on tap? There are preexisting solutions involving wood, and some of them are flexible enough to allow you to burn corn husks, stale bread, and dung.
Old 02-11-11, 10:48 PM   #3
Drake
DIY Guy
I guess wood would be what I would like to use as it would be available free. Useable indoors.
Old 03-17-13, 11:51 AM   #4
Drake
DIY Guy
Default Heating DHW with space htg stove?
Anyone using a space heating stove to heat their DHW as well are there problems with overheating water system if space heat is needed and water is not being used? I know pressure relief is in system put extra heat in water needed to be shunted if not used? I don't expect the demands to be overly unequal most of the time but wont to be safe if it's needed.
