Old 05-05-11, 04:42 PM   #731
pachai
Renovator-in-planning
Originally Posted by tweeker View Post
Until I figure out how to post pics....
Tweeker,
this may help - I also find it annoying to learn a
new user interface for every forum.
(Solution, join only the best forum around - this one :-)
Above the compose window is a row of icons...
including a smile face and undo and redo icons....
and a paper clip icon. Click on it.
A File selection dialog will open.
Once you have uploaded files,
(in my experience), you need to go
to the icon again and choose Insert All.
then you will see the ATTACH markup
in the text, and can move it around.
Hope this helps.
Sorry if this is wasted bandwidth.
Seth
PS the pictures are
My homemade heat plates fresh out of my folding jig
Plates as installed, with the groove
created automagically when they are stapled (UP).
pachai is offline   Reply With Quote
Old 05-05-11, 05:12 PM   #732
randen
Uber EcoRenovator
Default test
Opps playing with the postings of pictures
AC Hacker how do you post such nice large pics in the posts
Thanks Randen
Old 05-05-11, 07:56 PM   #733
...AC Hacker how do you post such nice large pics in the posts...
You have to start with nice large pics.
If you go through some of the pics, you'll see that there is a maximum size, beyond which the blog software will reduce the screen pic size and give you a couple of 'handles' to click on that will show you the full size item.
I generally try to keep the pic size smaller than the 'resize' limit.
But if you are asking how I do centered, in-line pix, here's a link I posted as to how I do it.
Hope this helps.
Regards,
Old 05-08-11, 05:53 PM   #734
Blauhung
found a quick article on re-purposing treadmills to power tools
Use a Treadmill DC Drive Motor and PWM Speed Controller for powering tools
Portland area seems to have more than a few used treadmills that i'll be looking around at this weekend along with maybe an AC unit.
AC, if you feel like parting with one of your lower end compressors I might be able to make ya a deal there too.
Blauhung is offline   Reply With Quote
Old 05-09-11, 10:32 AM   #735
tweeker
Green Energy Pioneer
Default Pictures test of A/C chiller
Hopefully it turns out?
tweeker is offline   Reply With Quote
Old 05-09-11, 10:36 AM   #736
tweeker
Default Well I got 1 photo to post, A/C Chiller -15 C
Froze the outside of the plastic test container.
Old 05-09-11, 10:39 AM   #737
tweeker
Default Encapsulating the Compressor
Test this weekend showed 9,426 BTU's @ 420 Watts of power, of which 50 of those watts were from my 12 Vdc water/fluid pump running of from a solar charged battery.
Name:	AChackOPERATINGroomWEEK3 003 (2).jpg
Old 05-09-11, 11:02 AM   #738
S-F
You Ain't Me
S-F's Avatar
Tweeker, when people do this for cooling the water in their computers they put the whole assembly in a cooler.
Water_Chiller gallery - XtremeSystems Forums
Old 05-09-11, 08:21 PM   #739
That figures to a COP of 6.6
That's pretty high. I hit COP near that a fews time, and then only momentarily.
I'd be interested to know the details of your test.
Old 05-10-11, 11:02 AM   #740
tweeker
Hi AC,
I figured how to post some photo's.
I don't have the test sheet in front of me, but this is the jist of it:
FWIW - Ambient Temp 68 degrees
Basically I was pumping/circulating 50 Gallons of water to/from tanks/exchangers per Hour, plus the 2.5 lbs of water in the lines = 419 Lbs of water
Temp Out of the heated tanks was 102 degrees
Temp Into the compressor tank (and then into the Condensor tank) from the heat exchangers was around 79.5 degrees.
419 Lbs X 22.5 degrees = 9,427.5 BTU's
I think I figured it correctly ?
