Old 03-01-17, 08:57 AM   #1
sunspot
Default battery equalization and diversion loads
Is there a simple/elegant way to automatically disconnect diversion loads while batteries are equalizing?
Small, single panel (190 watt), off grid, 24 vdc system. PWM controller.
Thanks folks!
Greg
Old 03-01-17, 10:30 AM   #2
Fordguy64
Hmm not sure on an automatic way. But I'm assuming you have to manually put the controller into equalize mode. If so you just put a switch or breaker of some sort before the dump load.
The Following User Says Thank You to Fordguy64 For This Useful Post:
sunspot (03-02-17)
