Old 03-23-20, 12:22 PM   #1
pinballlooking
pinballlooking's Avatar
Default Harbor Freight sandblast cabinet heavily modify.
I needed a sandblast cabinet but did not want to spend a bunch of money. I still needed it to work well.
I did some research. The are many videos with mods out there. lots of helpful ones.
Someone sells a kit with the upgrades but that was to expensive for me but those upgrades are very good. I just rolled my own as many other have done.
https://www.harborfreight.com/abrasi...net-68893.html
https://www.harborfreight.com/5000-l...dia-61870.html
I used just about a whole tube Polyurethane adhesive to seal the bottom.
You do not want to use silicone caulking if you are going to be powder coating.
I removed all the foam that came on it everywhere except the door and the top glass.
I bought glass a lowe’s 24” x 36” and will cut it into 3 pieces. Under $15 This will replace the plexiglass this gets all scratched up.
I used a roll 3M VHB Waterproof Foam Tape for all seams in the top.
I closed off the top back baffle. (that will now be the air in let.)
I added a side baffle. That will now be the vacuum outlet.
I added foam insulation between the bottom and the top.
I am adding DIY metering on the bottom. Made from PVC and black iron at the top.
I cut the bottom tray you put the parts on to allow more room in the cab.
I added Eastwood foot peddle and nozzle.
https://www.eastwood.com/eastwood-bl...l-and-gun.html
I bought replacement hose at lowes for the media hose as Eastwoods was too short.
I bought something similar to dust deputy for my shop vac on amazon.
https://www.amazon.com/Cyclone-Colle...55&s=hi&sr=1-4
I have a Harbor freight variable speed controller for the shop vac.
I added LED light.
As soon as I started using it my shop vac it stopped working. I took it apart and the switch was fine then I looked at the thermal overload was good to my surprise.
I found the issue. You can see here the wire for one of the windings was broken. I will fix this after work.
I am using a bucket Vac but the 5-gallon shop vac worked so much better.
Here is a tractor step I sandblasted and powder coated. It is shipping to a customer today.
The only thing I need to seal up is the door.
I need to add some flashing to the door bottom.
I don’t want it to get a direct spray.
ID:	8878   Click image for larger version
ID:	8879   Click image for larger version
ID:	8880   Click image for larger version
ID:	8881   Click image for larger version
ID:	8883   Click image for larger version
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
The Following 2 Users Say Thank You to pinballlooking For This Useful Post:
Daox (03-23-20), WoodBurner (03-23-20)
