Old 07-11-16, 05:56 AM   #11
STM
STM is offline   Reply With Quote
Old 07-11-16, 08:22 AM   #12
if you are doing co2, DO use a regulator. It likes to pop hoses. Then what you end up with is a fire extinguisher with a frozen shutoff valve. Definitely worth it.
STM (07-12-16)
Old 07-11-16, 09:07 AM   #13
STM
Hm, if that's the case then a 5lb industrial style tank may be better. Easier to fill locally. I have a MIG flow regulator, would that work for purging if I swap the tank side nipple out to fit the co2 tank? I know I'm jumping around with my questions, just trying not to spend tons on something that will only get occasional use for purging.
Old 07-11-16, 09:16 AM   #14
STM
Here's my regulator. Victor inert gas, max inlet pressure 3000psi. Seems like it would work for purging, since we wouldn't be trying to build pressure.
Old 07-11-16, 01:45 PM   #15
Welding regulators usually have a max pressure of 50psi.
That's what I have mine set at.
STM (07-12-16)
Old 07-11-16, 10:45 PM   #16
Perfect tool for the job. You may be able to cheaply rent a cylinder that would screw right into your regulator. Pay deposit, use the thing, get back deposit minus rent and weight of gas used.
STM (07-12-16)
Old 07-12-16, 03:16 AM   #17
STM
Cool, that's what I'll use then. I'll call the rental place and airgas to see. If I can't rent then I can get a 5lb bottle on ebay or amazon to fill or swap. GCA320 nipple only $10 so no issue getting the reg on the tank. Thanks for the heads up on the possibility of short term rental.
Old 07-12-16, 09:51 AM   #18
Watch craigslist CO2 cylinder. I bought one cheap off craigslist and turned it in for a welding cylinder. They gladly exchanged it for any type cylinder same size.
Old 07-12-16, 10:19 AM   #19
mejunkhound
+1 on watch CL
Got an 80CF bottle and regulator for $20 last year.
Last week got a Lincoln portapro O2 and acet bottle with hoses and torch for $20 at a moving sale
keep your eyes open and check CL and garage sales often.
Old 07-13-16, 02:28 AM   #20
STM
75/25 argon/co2 works fine for brazing right? Bottle is more expensive but then I'd have a bottle to convert my Lincoln flux core welder to MIG.
Edit: I see elsewhere this was tested and confirmed, so there we go. More expensive bottle but more use too.
