Old 11-16-11, 02:01 PM   #11
Patrick
Do they use any cement to hold them together?
Old 11-16-11, 02:35 PM   #12
bennelson
Home-Wrecker
The project used earth bricks to build a workshop building. On that building they used cement mortar between the bricks.
They found that did NOT work well. The mortar liked to break away from the bricks. The building itself is really neat looking, but the combination of cememt mortar and earth bricks really didn't work.
For the building worked on in the video, it DOESN'T use cement. Each brick gets an earth slurry, which makes the edges sticky and seals it to the other earth bricks it touches.
As far as I could tell, it seemed to make a very solid bond.
Old 11-16-11, 04:26 PM   #13
Patrick
So no cement actually in the bricks?
Old 11-16-11, 04:55 PM   #14
TimJFowler
TimJFowler's Avatar
Adobe blocks have the same issue with cement stucco. Cement-based stucco expands and contracts with moisture and heat differently than adobe and will crack and fall off. Mud-based stucco is much more compatible, though it also needs maintenance.
FWIW,
Tim
brick, clay, earth, ecology, open source
