Old 02-11-16, 02:20 AM   #1
weightlose
how to lose weight fast
Post Split install
How to I install Split install
weightlose is offline   Reply With Quote
Old 02-11-16, 04:27 PM   #2
Depends on what you have. Easy answer:call up a licensed pro or give up warranty and insurance. If something goes wrong with the self-install and your house gets damaged, don't try to file a claim.
AC_Hacker (02-16-16)
Old 02-16-16, 08:29 PM   #3
The first thing you want to do is make a guess about the brand name
and the model of Mini-split you might want to install,
then download and study the installation manual.
Then take a look at the threads on this page about installing mini-splits.
There used to be some pretty good install videos on youtube for a few brands..
Old 02-21-16, 10:57 AM   #4
WyrTwister
Ask yourself , how much HVAC or construction or DIY experience you have . Same question on tooling .
Ask yourself how much studying you are willing to do . How much work you are willing to do . Will you have any help . What is their knowledge base .
How much are you willing to spend on tooling ?
Most anyone can buy a window unit , set it in the window , adjust the side pieces , close the window & plug the cord in ( especially if the unit is 120 VAC ) .
Any kind of split system involves dealing with refrigeration lines and refrigerant . And all that entails . Are you up to that ?
So , if you are going ahead with it , sit down and start making a list . What room do you wish to install the mini split in ? How many square feet is the room ? Does it face N , S , E or W ? Sots of windows or few ? How well is it insulated .
Now , you can start to decide the capacity ( BTU's ) you will need . If you need help , ask and I am sure someone here can help .
Now , decide on your budget . Figure out what your tooling cost will add up to . Subtract that from your budget . The difference is the amount you have to spend on HVAC equipment .
I recommend you buy the highest efficiency equipment , that you can , with in those dollar amount .
We have installed 2 MS's in out house . If it was not for cost , I would install more .
God bless
Wyr
mini split, mini splits hp, mini-split, minisplit, splitter
