Go Back   EcoRenovator > Improvements > Biofuels
Old 11-03-15, 06:36 AM   #11
Don't be shy. What you are doing is very useful and interesting.
Old 11-03-15, 10:19 AM   #12
Fordguy64
Well I added a new photo to my album on here. My phone crashes when I try to add the photo to the post but it shows the basic idea of the heat exchanger.
Old 11-03-15, 11:58 AM   #13
I added a few of the pics in your album to your post for you. This is a very interesting project.
Can you tell us a bit more about the burner itself?
The centrifuge would also be very interesting to see and hear about.
Old 11-03-15, 05:15 PM   #14
Fordguy64
thanks for adding them.
here is another video of just the burner running
https://youtu.be/q1div6g1yho
this is the part number for the nozzle im using 30609-2 and the nozzle body is 17147
those are the only parts i have bought so far. everything else has been stuff i have had on hand.
i will work on the details of the centrifuge soon.
Old 11-03-15, 05:19 PM   #15
Is it really as loud as the video makes it seem?
Old 11-03-15, 07:55 PM   #16
Fordguy64
its not that loud but it does make some noise. thats actually something ive noticed about the videos too not sure what it is about my phone that makes it seem so loud
so today i was messing around with some different burner designs.. i came up with this, basically it goes from 2.125" tube to 1.125" tube. the video doesn't really do it justice but it really focuses the flame into a longer skinner flame and i think i like that better
https://youtu.be/o16Y4BINhgs
Old 11-03-15, 09:42 PM   #17
Perhaps if you can talk a little it'll put the sound into perspective.
Old 11-05-15, 07:28 AM   #18
Robaroni
Robaroni's Avatar
Ford Guy,
I like the idea but how do you regulate the temperature? Once the water gets to about 120 to 125F I'd want to shut off the burner. Is there an easy way to automatically turn it back on when the temp drops below a specific level? It seems to me these are a little tough to get going.
Rob
Old 11-05-15, 07:16 PM   #19
Fordguy64
Daox i made a video but you cant really hear me haha but im pretty soft spoken so ill try again this weekend hopefully and ill got over my "silent" air compressor and the centrifuge at the same time.
Rob my plan is to heat water and then pump it into the house into a heat exchanger. This is also part of the reason i went with the smaller nozzle so i could just load up the fuel reservoir start the burner and pump and walk away.
the water tank will probably remain an open system at least at this point just so i dont have to worry about a tank exploding if something happens
also i think i have finally decided on a burner design. over the last few weeks i have been tweaking the burner a little and im finally happy. it lights up easy gets hot fast and burns clean!
Old 11-06-15, 05:44 AM   #20
Robaroni
Robaroni's Avatar
Interesting, do you still have to prime the burner with kerosene to get it started?
