Old 06-27-17, 11:54 AM   #21
buffalobillpatrick
Hey Sully01,
I'm a retired software engineer, micro code, power on self tests on many types of disc drives, tape drives, storage controllers, printers.
Old 06-27-17, 11:58 AM   #22
buffalobillpatrick
I have been studying hot water floor systems since I retired in 99.
Have designed & installed 4 systems, this is my 5th.
Learn on every one.
Old 07-07-17, 01:53 PM   #23
buffalobillpatrick
I have made a little progress:
Main lower level of house walls have been poured: 8" concrete x 10' high, a 30' x 48' rectangle walk out basement.
I had the windows bucked in so that windows & doors sit into a 5.5" x 1.5" recess all around on the outside, so if they ever leak water goes to outside.
Windows & sliding doors are Andersen Series 100 Fibrex
Attic trusses are on site and I have added the 16" gable end overhangs.
The gable end trusses have the 2x4's laid flat, on them I glued & shot 8 penny nails 1/2" CDX plywood, primed all seams with Glidden Gripper, taped with 3-M all weather tape,
Next layer is 30# roofing felt,
next layer a drainage plane of 1/4" Benjamin Obdyke Home Slicker + Typar,
next layer is 1/4" 4x8' sheets of James Hardie exterior cement board with all seams taped with cement board mesh tape,
next layer is a base coat of Styro TuffII synthetic stucco,
now they are ready for the crane to hang, but 1st I have to backfill around sides & rear,
before that I have to have the footer drainage system inspected,
then install the 1" PEX water line in, the 4" sewer line out, & the 200 Amp power line in,
the 1,000 gallon cistern & float switch wires,
inside the cistern I will put a 300' of 1" pex to be used for cooling upstairs in summer.
Whew! just getting started
The Following User Says Thank You to buffalobillpatrick For This Useful Post:
Daox (07-07-17)
Old 07-07-17, 03:16 PM   #24
Congrats on getting started.
We need picture!
buffalobillpatrick (07-08-17)
Old 07-07-17, 03:56 PM   #25
Awesome progress! Ditto on the pictures.
Old 07-08-17, 12:30 PM   #26
buffalobillpatrick
As my computer crashed, I'm on a public library computer.
All my photos are on my Iphone.
I selected 5 pics on Iphone & am in VERY SLOW process of them hopefully uploading,
seems to be choking at 2 bars signal strength.
Old 07-08-17, 01:29 PM   #27
buffalobillpatrick
Hope these pics work
ID:	7820   Click image for larger version
ID:	7821   Click image for larger version
ID:	7822   Click image for larger version
ID:	7823   Click image for larger version
ecomodded (08-19-17)
Old 07-08-17, 02:17 PM   #28
buffalobillpatrick
1st pic is above rear of house looking East, the front door in middle is 8' high, the windows on either side are 7' x 5', the sliding door on the right (South) is 8' x 8',
the rear (West) bedroom window is 4' x 4' egress,
the front (East) 40% 12'-8" wall is on a 32" step down footer, as this dirt (haha) is decomposed granite (small rocks) and dry, this is all I had to go down by IRC code, the space inside the wall gets 7-8” thick type 2 EPS
2nd pic shows the 27' retaining wall 10' tall with a buttress on back side (dead man), on front (East) side will be parking & BBQ area by slider.
3rd pic shows the North wall buttress, required by my Structural Engineer due to 48' wall length & 8' of back fill.
4th pic shows the front (East) gable end (bedroom) with a 6' x 6'-8" sliding glass door opening out to a 12' x 20' balcony/carport.
The lovely purple color is what I got when adding dye to the Styro TuffII, not what I was shooting for, so I call it a base coat.
5th pic shows the rear (West) gable end during assembly, has a 4' x 4' slider for a 2nd upstairs bedroom egress.
Old 08-19-17, 02:39 PM   #29
BuffaloBill I like your work Im planing my first build for next year using ICF's.
have you considered using rigid insulation on the outside of the basement ? it would be first on my list so thought I would bring it up.
buffalobillpatrick (11-05-17)
Old 08-26-17, 12:43 PM   #30
buffalobillpatrick
I agree with Martin Holiday's + and - recent comments on this Greenbuildingadvisor.com
My inner layer is 4" of Polyiso foam which can't be in contact with earth (gradually absorbs water)
http://www.greenbuildingadvisor.com/...-basement-wall
http://www.greenbuildingadvisor.com/...ers-spray-foam
Trying to upload latest pics on cell phone is not working, hung, 2-3 bars signal strength
got this message "your submission could not be processed because a security token was missing"
I give up
I found that I could upload 1 pic at a time
