Old 09-03-13, 12:01 PM   #21
Any chance I could get any of you guys to check your router's power usage? Mine is pretty old and I'm wondering if the new ones with multiple antennas use more power (I assume they do).
Old 09-03-13, 12:41 PM   #22
Wooo, I found a nice site that lists power consumption of a bunch of routers! Looks like the one I have running at 5W isn't all that bad power wise compared to most. Most seem to be in the 5W-10W range.
WIFI Routers Power Consumption
Old 09-03-13, 01:46 PM   #23
I went ahead and rolled the dice on the Edimax BR-6228nC router. Its has the lowest power consumption (1.5W!) of all the routers on the power consumption database site and has the features I want (wireless N basically). It is also dirt cheap at $20 shipped from newegg. I'll update you all on how it works out.
Product webpage: http://www.edimax.com/en/produce_det..._id=1&pl2_id=2
Old 09-03-13, 08:24 PM   #24
Best advice I know of is to get all equipment that runs from 12V and then connect them all to a 12V battery with a 13.8V float charge (and/or alternative energy) to run them. It's far more efficient to have a single converter than many and also much more reliable.
Old 09-04-13, 10:29 AM   #25
I agree that would be nice. I'm pretty sure my current router runs on 5V and this new one I'm know runs on 5V.
Do you know of any good/simple way of kicking down 12V to 5V. I know there are the linear voltage regulators like a 7805, but they just waste the excess energy as heat, right?
Old 09-07-13, 11:05 AM   #26
Exalta-STA
IThe phone company provided me with a modem and Wireless-N wifi router combined in one unit. Total consumption is just 9 watts
Modem: Zyxel P660R-D1
Exalta-STA is offline   Reply With Quote
Old 09-07-13, 01:41 PM   #27
I really like the TI voltage regulators. They're switchers that are almost as easy to use as linears.
You can also look at those automotive USB power supplies. Derate them significantly and they should last a good time.
Daox (09-08-13)
Old 09-08-13, 09:15 PM   #28
ATLleaf
i want a wifi repeater
ATLleaf is offline   Reply With Quote
Old 09-08-13, 11:43 PM   #29
The TL-WR703N appears to be cheap, popular, and well supported. It accepts 5V, so you'll need a DC/DC to run it from a 12V system. A cheap car USB charger will work fine and the power usage is very modest (less than a watt) so just get a charger rated for at least 500mA (derating it since you'll be using it for continuous duty) and you should be good to go. As a bonus, it can also work as a NAS, though plan on using a larger converter (one designed for charging tablets should work nicely) if you're going to use a hard drive.
Old 09-20-13, 12:02 PM   #30
I have my new router, but I have yet to set it up. Hopefully sometime this weekend...
