Old 08-24-11, 09:00 AM   #11
S-F
You Ain't Me
S-F's Avatar
Get a pressure tester so you can verify for yourself that it can push out 3.5 Lbs. Make a test box. Build a 16" O.C. box out of 2x4's. Cover the back with OSB or something and mesh off the front. Make it tall enough to give you a sense of how filling it all up works. I'll be easier to tear the cellulose out of a bad test box than an entire cavity.
The Following User Says Thank You to S-F For This Useful Post:
AC_Hacker (08-24-11)
Old 09-09-11, 08:10 AM   #12
hamsterpower
I just did this last weekend in my kitchen project. I'm not sure if my job is up to dense pack standards, but with my open hand, I can not push into the cellulose at a test hole. I think it worked very well.
Here's what I did.
I rented the basic machine from Lowes. Set the adjustable plate at the output to about 25% open. Bought a 1 7/8" diameter universal vacuum hose and taped the included adapter to the end of the long 3" diameter hose that came with the blower. Then I pulled the hard adapter out of the flexible vacuum hose at the very end. This was so it would flex enough to pull out of the wall while blowing.
I used a 3" hole saw to drill a single hole at a time in the inside of the wall to be insulated. I did not want cellulose to blow out empty holes nearby. I drilled these holes about 6 foot high as the vacuum hose was 6 foot long.
The thin vacuum hose slid down the wall easily and I wrapped a towel around the hose to seal the hole. with the machine running I could hear when it bogged down. When this happened I pulled a few inches of hose out of the wall. When the hose got close to the hole I quickly turned it and pushed it up into the top of the wall, two feet above.
I did drill a few test holes to check the results and as I said above. I could not push my open hand into the cellulose.
To finish up I sprayed "Great Stuff" foam in the holes and pushed the plugs from the hole saw back in. As the foam cured I adjusted the plugs to be flush with the wall surface.
A note on prior steps: I had these walls open the week before and sealed everything with 2 -3" of spray foam from "Tiger Foam". I also made sure there were no barriers to keep the cellulose from filling the cavity.
The end results, I estimate an R-value of 39.5 where at best I had R16 before, and nearly a complete air seal.
Old 09-09-11, 09:04 AM   #13
How thick are your walls?
Old 09-09-11, 10:14 AM   #14
S-F
You Ain't Me
S-F's Avatar
I was at Lowes the other day and saw their cellulose machine sitting out and I don't have the slightest bit of faith that it would be able to achieve a dense pack that wouldn't settle or wouldn't leave big holes. I think that calling rental centers to find a Force 1 or 2 would be what you'd have to do.
Old 09-10-11, 05:46 AM   #15
hamsterpower
They were 2x4, now they double 2x4 with a small gap between = 7.25".
| 3.5' | .25"gap | 3.5" |
Old 09-10-11, 05:51 AM   #16
hamsterpower
The key was setting the adjustable plate at the output to 25% open. This way the full volume of the blower air was pushing a small volume of cellulose. I am confident that it is packed enough to never sag. Maybe not up to dense pack standards, but it won't sag. That was my goal.
Old 09-10-11, 08:35 AM   #17
S-F
You Ain't Me
S-F's Avatar
You have to do the same thing with a brand new Force 2. If the blower can't put out 3.5 lbs at the hose you can't get a dense pack.
blower, cellulose, dense pack, diy, insulation
