Old 10-31-10, 08:04 PM   #11
Nope, I haven't replaced anything. I've been in the house just over 2 years now and am just getting to some of this stuff.
Old 10-31-10, 08:17 PM   #12
Patrick
You might want to at least take a look at the anode rod then. It's sacrificial and "wears out" over time, giving up its metal in a galvanic reaction instead of the inside of the tank getting corroded. If it's bad, you might be able to get a few more years out of your heater by replacing it.
Old 11-01-10, 10:06 AM   #13
Higgy
The Gardener
What's the standard amount of time before replacing your water tank? Is it 10 years?
Old 11-01-10, 10:46 AM   #14
I've heard ~15 years.
Old 11-15-10, 08:52 AM   #15
Higgy
The Gardener
Ok, so I did the same dump to my water tank last Thursday. Would have posted sooner but I couldn't find this post. It's an electric water tank. Turned off the water and the power, emptied the whole tank, blasted it a few more times with some extra water until it looked mostly clear (it was so sloooow), then filled er back up. When I turned all the taps back on though, I forgot to remove the aerators from the taps. Is that a big deal? I'm going to try to remember to remove them tonight and clean them out if they're dirty.
Old 11-15-10, 04:37 PM   #16
RobertSmalls
RobertSmalls's Avatar
Higgy, did you have any sediment in the first draining phase? Lots in the post-rinse phase?
Old 11-15-10, 07:52 PM   #17
Higgy
The Gardener
Lots in the first draining phase...then not as much in the second 2 I don't think. I didn't really stick around to watch it pour out. It took forever.
Old 11-15-10, 09:07 PM   #18
RobertSmalls
So, I guess I had no sediment in mine, even though it hasn't been drained in at least 1.5 years. I'm running Buffalo city water, which is good stuff, but not free of minerals.
Old 11-15-10, 10:57 PM   #19
strider3700
looking for info on water tank comparisons I came across this site
Emergency Preparedness: How to make sure your water heater can be used as an emergency water supply
There they discuss a lot of issues with various hotwater heaters including ultra slow drain times, crap in the tanks and the crappy drain valves clogging and leaking. They recommend replacing the drain valve with a better off the shelf one to allow you to actually get all of the water out easily/quickly in the event of an emergency and you needing to drink that water.
They had tons of info on the tanks, various setups and options.
Old 11-17-10, 09:45 AM   #20
I've been told that if your water heater is over 10 years old that I should not be suprized if I can't get parts (thermostat or whatever) for it any more as they don't expect them to last that long, warranty's range from 6 to 12 years, I haven't seen any longer then 12 years but I have seen water heaters last much longer then that and some fail after 5 years.
I'm not sure why you would turn off the water and let the tank fill with air, I always drain mine with the water on and it flows clear after about 5 gallons but starts out with a nice brown sludge.
clean, drain, maintenance, sediment, service, water heater
