09-20-16, 05:21 PM | #71 |
Very nice… good to see it up and running.
I saw those hard lines in another post and I just might make a set of them myself.
09-20-16, 11:03 PM | #72 |
If you want to get as close to an absolute vacuum as possible, hard lines are the way to do it. I have gotten down below 100 microns with them as well. But according to most (if not all) manufacturers, this is not necessary for reliable operation. How deep is sufficient is specified differently in service manuals made by different manufacturers.
09-21-16, 01:41 AM | #73 | |
09-21-16, 01:53 AM | #74 | |
09-21-16, 09:08 AM | #75 | |
'Do not go below this' limit.. While studying for the EPA type I test, I read something like "there is no such thing as too much vacuum".. IIRC, on the old Sanyo that I repaired, some R410A was leaking out of the ODU, and into the lineset, while I was trying get a good vac.. It was very hard to get down under 200. Should have used copper lines!
09-21-16, 09:16 AM | #76 | |
A real pro would never use DIY copper vac lines, because they aren't going to be very durable. After a dozen installs, they would start wearing out.?. Just have to buy the very best YellowJacket lines.. But this idea is prefect for us DIYers who only do a new install every 8 or 10 years.. I'm hoping this new Gree will last about 15 years..
09-21-16, 09:31 AM | #77 |
Think I have read 500 microns is OK .
Then there is the 3rd world method . God bless Wyr |
09-21-16, 09:31 AM | #78 |
How much faster did it drawn down the vacuum with the hard lines.
09-21-16, 10:39 AM | #79 | |
but I feel it cut the over-all time about in half.. I didn't rush it at all. But that's likely because of my cheap hoses. I have one short hose that I purchased way back when, and another one just like it is on the way.. Maybe get here today.. https://www.amazon.com/gp/product/B009AX3EQ0 With two, (gauge in middle) I could possibly get a system down under 100 microns.. Maybe. With copper, 100 would be pretty much a sure thing.. What really impressed me with the copper, was how fast I could get the copper lines(only) down to around 46 microns! I know they are short and the ID isn't that large, but still impressive.. During vac/dehydration, when the 'stable' LED would come on, I would shut the cut-off and watch the gauge plummet quickly to less than 50.. Flip the cut-off back open and yank some more moisture out of the lineset.. Kept doing that until the stable LED was coming on, around 100 microns.. I could have done the whole operation a lot faster, if I wanted to hit 200.. But, I was interested in seeing how well the DIY copper vac lines would work. They work very well.. I Highly recommend them to DIYers.. And you get to make practice flares! Test your pump etc.. This really is a hobby.. Not really Rocket Science, unless you want it to be.. Sometimes it can be frustrating, sometimes satisfying. We just came back from a nice walk in the sun.. The house was too warm.. But that changed in about 5 minutes.. I looked at the TEDs, last night it was cool, so the old Sanyo used 0.4 KWh heating the pump crankcase/oil.. But, the new Gree didn't turn on any heat.. It didn't use any power over-night.. Nice! Maybe it triggers at a lower OD air temp..?.
09-21-16, 10:59 AM | #80 |
Can you tell how it is doing compared to the Sanyo heating or cooling?
"Sanyo used 0.4 KWh" That could add up to a good savings over time.
