Old 01-17-15, 08:18 PM   #1
shadowaxe356
Default Hello from Ohio
Hello, My name is Tyler I'm 23 and i'm planning a solar system on my house to be purchased and installed by my family and myself. I have a ton of questions and ill post them in another thread. Thanks for your time!
shadowaxe356 is offline   Reply With Quote
Old 01-18-15, 05:57 AM   #2
Tyler, welcome.
First, do some homework. You probably know that there is a federal 30% tax credit, but also find out if Ohio, or your utility, offers more credits. To get the federal tax credit, the system must be installed, operating and be approved by the utility (if on grid) by Dec 31, 2016.
On grid or off grid?
If on grid (or grid tie), find out what your utility requires. Can you do the installation yourself? Sadly, some communities and utilities mandate that a pro do all the work. Regardless, you MUST have a licensed electrician do the final hook-up. Failure to do that will nullify your home insurance and prevent you from connecting to the grid.
Find out, if you are doing a grid tie, what the net metering specifics are. This can make or break an installation in terms of pay-off.
Go to PVwatts and put in your location, and proposed orientations. Estimate how much room there is on your roof on the exposure you want.
Get out your utility bills and figure how many kWhrs you use in a year. Not critical, but helpful to know. Know exactly what a kW hr costs in different times of the year.
The self installed cost of a PV system (excluding an electricians hook up charge) is about $1.60 per watt (before tax credits/rebates). This includes the panels, inverters, racking, wire and disconnect panels. If you want to do off grid then it is about 5 times higher due to batteries.
I am in the process of doing a 10 kW on grid Enphase based PV system here. There is a LOT to be learned from Pinball and others that have put in substantial systems.
But do the homework and do NOT get sucked in by companies that put up the PV panels at no cost to you.
Again, welcome.
Old 01-18-15, 10:50 AM   #3
shadowaxe356
Tyler, welcome.
Again, welcome.
Its going to take me about another year to save up, maybe two. So i have time, I have done about 20 hours of research but my computer has limited access. Im trying to do a grid tie at first and then move into a hybrid system after i start producing more than i use (and get credited) and then purchase battery and a new hybrid controller etc. I don't know if all my math is correct and also do i have to use a single charge controller or can i put multiples together to match the amps? also can you have a system start with a central inverter and add micro inverters just encase of shading and rain?
Old 01-23-15, 03:00 AM   #4
thewalf
Welcome to our community
Thanks
thewalf is offline   Reply With Quote
diy, solar panel
